Volks AutosMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 44
Like Tree1Likes
Thread: Led change in dial cluster
    Feb 2013
    262
    Hi guys, couldn't seem to find anything in a search about this, I want to change the smd's behind the three lcd displays in the instrument cluster, i want to create the facelift look with the white text, I've dismantled the unit to find some orange filter plastic in there, now I imagine that putting white leds in there will just shine through orange, so has anyone else done this?
    I changed to white on my last car (non audi) but it was straightforward as there was a clear filter in there
    I could take out the orange piece but I will probably get hotspots and I can't be arsed making a replacement filter
    Help appreciated :-)
    Audi S3 : revo stage 2+
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,967
    Im doing this at the moment with a set of 8L clocks and B5 clocks.
    Just waiting for the LEDs to turn up and do some parts shopping.
    When I did this with my BMW, I used polystyrene cups and plates.
    Cut them to shape, flatten and fit. Worked a treat.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Feb 2013
    262
    polystyrene? I wouldn't have thought it would let much light through, or did you mean the white plastic disposable cups?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,967
    Quote Originally Posted by R34nel View Post
    I think that's what its called.
    The white plastic cups younger at cafes.
    The clear ones are no good,p. You need something in there they will bounce the light around to remove the hotspots.
    I got some PC packing frosted plastic bags style bags from work to try.
    I can post some up if you want.
    Feb 2013
    262
    thanks for the reply, if I'm going to change them I need to do it today as I don't want to take them apart again, ill see if I can find something decent around the house, if not I won't bother
    Jan 2013
    159
    Sweet wrappers take some pics as well
    Dec 2012
    Hordnean, Hampshire
    157
    I do this kind of thing as my sideline and have experience with Gen 7 Celica's and their LED lighting. To change the display to white you will indeed need to add white LEDs but also remove the orange filter as you suggest. You still need to use a white diffusion filter to get an even light, which I can provide for a nominal fee. It has similar visual qualities to tracing paper but is heat proof and wont degrade. There's examples of my work on my Facebook page if you're interested - http://facebook.com/skewernmb
    Feb 2013
    262
    I used to do this a fair bit also but on the vxr scene but the filter was white anyway in those cars, I've made a filter and changed the leds behind the mileage display only to see how it looks, I'm pretty happy with it but the filter I used was about double the thickness of the standard orange piece so takes a little of the brightness away, when I open up to do the rest I will need to use a slightly thinner material, but all in all should turn out good when I finish it off
    Feb 2013
    262
    Opinions welcome
    Dec 2012
    Hordnean, Hampshire
    157
    Doesn't look too bad, but a little yellow and dull as you mention, and likely to go more milky over time. I also have a very pale blue filter which gives a much crisper white light. Not a problem sending over some of the designed for purpose filter
    Feb 2013
    262
    Here is a photo with the engine running, the displays get brighter
    The yellowing you mention isn't there in the flesh, seems to be something the camera picks up, if you could sort me out some filter material that would be cool, I would need enough for all three displays though?
    Feb 2013
    262
    Just read a thread where Someone mentioned that putting a blue led behind the orange filter makes white, not sure if anyone had tried this but I may have to experiment!
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Wouldn't it be easier to just swap out the old red one and code the new black and white one
    Dec 2012
    Hordnean, Hampshire
    157
    It will just make it dull brown, not worth trying
    Feb 2013
    262
    Quote Originally Posted by Digzz View Post
    lol of course not! it's not difficult to swap some leds and a piece of plastic, plus future buyers may be suspicious about mileage on a car that's had it's dials replaced
    Feb 2013
    262
    Quote Originally Posted by mookster View Post
    Tried it with a loose blue led I had, just looks like a more pale orange
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Mileage can be corrected very easily for around £50 mate....
    Sep 2012
    Prague, CZ
    88
    Nalin & Kane - Beachball, followed by Delerium - Silence.... nice
    2009 A3 TDI 170 STronic SLine
    Feb 2013
    262
    You know your tunes, it's trance anthems 2008
    Feb 2013
    262
    Little update, used some proper filter plastic and here are the results, it's not how I intended as the background is blue however it looks great when driving, looks much more modern and cleaner than the red.
    I can only imagine that the facelift must use a different type of LCD to keep the background so dark whilst text is lit bright white
    The top of the LCD (above the line) changes to red when is would go orange normally (ESP off, washer fluid low etc etc)
    SCFC_Messiah likes this.
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    [QUOTE=R34nel;1851706]Little update, used some proper filter plastic and here are the results, it's not how I intended as the background is blue however it looks great when driving, looks much more modern and cleaner than the red.
    The top of the LCD (above the line) changes to red when is would go orange normally (ESP off, washer fluid low etc etc)[/QUOT
    Hi R34nel, Sorry to jump into your thread but after reading the above and seeing the results, I must have this done to my car, love the blue look.
    Could you please direct me to the filters you purchased, do you have a guide or any tips/advice on completing the change? Any links would be great.
    Thanks in advance
    Feb 2013
    262
    I could give you advice on doing this to your dials if you like, how are you with soldering? There are 40 plcc2 surface mount leds that I changed to get this look, most people who are confident with an iron would be okay, I work in electronics anyway so am well versed in this kind of thing also the dial cluster and LCD displays appear very fragile when removed. The parts aren't expensive but it can be a bit fiddly
    I'm just giving you a heads up as I'd hate you to break your clocks!
    Mar 2012
    278
    Looks great. Now you have to change every single other red light/button to match
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    Thanks for the reply.
    40! Didn't realise it would be that many. My soldering is OK, although I haven't done it for a while. I did Electrical Engineering back on college and I do some soldering were I work, so pretty confident.
    I was trying to remove the cluster today, managed to get the cluster out no probs but I had difficulty removing the back cover of the cluster. I undid the 2 torx screws and un-clipped the clips but it seemed like the cluster would not pull apart......easily! Does it just pop off?
    Where did your purchase the LED's?
    Thanks again for your help.
    Feb 2013
    262
    yeah you need to remove the two Torx as you mention then undo them clips without the last one closing again, when there all open it will pull apart but it has two plugs holding two pcbs together which you will also be pulling apart so you may feel some resistance, although it shouldn't take decent force so remain gentle please! basically the blue plug on the rear of the cluster is on a pcb which is attached to the back cover you will be pulling this away from the rest of the dials, here's a pic of the pcb with the leds which are changed, there's 32 for the large centre display and 4 for each small display
    Feb 2013
    262
    Also I use www.crazyleds.co.uk to buy the leds and the filter plastic, it's not the cheapest place but I find they have decent quality and brightness, I've bought some crap ones of eBay in the past, you could use rapid or farnell but it's not as user friendly if you don't know what your buying, you want plcc-2 leds
  28. #27
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    Is it the 3020 or 3528 plcc-2 LED's?
  29. #28
    Feb 2013
    262
    You want 3528 mate
    You will need a second colour for the top bit of the large display also for when a message is displayed it changes colour
  30. #29
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    Just ordered the LED's and some plastic filter. Will give it a go this wknd and will post my results.
    Fingers crossed!
  31. #30
    Feb 2013
    262
    incase you are unsure, the leds for the top of the large display are in pairs, one white and one red, the red is the usual lit one and when the top of the display changes orange the white one is lit (obv shines orange through the filter)
    So you need to change the red one to your new colour (white?) and the white one to a second colour - I used red but you could use any colour, you could actually just swap the two leds over and would achieve the same effect but I prefer to use new as they can sometimes be damaged from the heat of the iron.
    If you are unsure or get stuck just change the left one of the two to white and leave it at that, this way the screen will all be white/blue but it won't change colour when there's a warning or esp is pressed, also incase you didn't know you can light an led with a multimeter, you would need to use the diode/continuity setting
    If you need any further help or what I've written doesn't make sense to you then just let me know :-)
  32. #31
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    Update.
    Had a go at this weekend on some old PCB's I had laying around.........fiddly little things aren't they!
    Managed to get a few soldered OK and tested fine but still unsure if I am confident enough to try on my dials!? Although I managed to solder some and they tested OK, it was still difficult and found hard to keep myself steady without melting the LED.
    As much as I would love to have this change, I may try and outsource the soldering 'somewhere, just encase I break something.
    Thanks for the advice R34nel but this mod is a little 'too' scary for me to attempt.
    Now just gotta find someone local to me who can solder them.
  33. #32
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    Plus the equipment I had was not ideal!
    Needed a much smaller iron tip.
  34. #33
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,967
    You want 3528 mate
    Thank's for the link.
    Just ordered 50 to do a set of test clocks.
    We'll see what happens.
    Quote Originally Posted by JRock247 View Post
    That's my fear, I've removed a couple as a test and my iron did ok but we'll see what happens when I set about doing them all.
    Thinner nib irons are cheap on ebay I think.
    So worst case, order one of them.
  35. #34
    Feb 2013
    262
    plcc-2 leds are pretty big tbh, using a big tip wil make them easier to remove also.
    ideally you would have an iron with a selection of tips (any half decent iron will have interchangeable tips) and they are a couple of quid a piece
  36. #35
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    My Iron does allow for interchangeable tips but the only tips I've got is a 1.8mm flat bladed type and 2mm round ball type, on the bay now looking for some smaller ones to try with.
    I did find the larger tip easier for removing the LED's but not for installing, need a smaller tip for that.
    Will update again this wknd.
    ScottB5/R34nel, if you guys have any tips/tricks when soldering these to make things a bit easier, let me know. Thanks
  37. #36
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,199
    yea for some reason its a very popular vxr mod, i remember my mates vxr!
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  38. #37
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,967
    I used a solder sucker to remove the bulk or solder.
  39. #38
    JRock247's Avatar
    Jul 2012
    Hampshire
    337
    Always have my solder sucker with me when soldering, very handy tool!
    Just ordered some smaller iron tips for my iron, so will give them ago on wknd and hopefully that will make things easier.
    Another issue I have when soldering these is keeping the LED in place for the 1st solder joint, it's OK when I have one edge soldered as the solder holds the LED in place for me to solder the other side. Any objections to 'sticking' the LED to the PCB first, with some sort of tack or tape?
  40. #39
    Feb 2013
    262
    I just use a pair of tweezers and an iron.
    Also using solder braid on the pads to remove the solder allows you to keep the new led sitting flat although this isn't necessary it just keeps it looking neat.
    Your not using a solder sucker to remove the leds are you?
  41. #40
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,967
    Nahh, just to help remove any excess.
    I've only removed two and it was easier with sucker lending a helping hand.
  1. What hardware is needed to change the instrument cluster?
    By Gustaf in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2009, 19:53
  2. Import A3 sportback 1.9tdi (ROI) - changing speedo dials from KM to MPH?
    By tates1979 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2009, 16:14
  3. Changing rear light cluster
    By FrOgR in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2008, 21:04
  4. Changing over Instrument cluster
    By f13ldy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2005, 08:07
  5. Changing the instrument cluster on an S3
    By jgrand in forum General Technical / How To
    Last Post: 17th June 2004, 13:38
