Chris NottMonster Motorsport
Results 1 to 15 of 15
Like Tree2Likes
  • 2 Post By mike foster
Thread: Windscreen wipers 2004 a3
    Apr 2013
    Hi just wondering if anyone can help me.
    windscreen wipers were working fine on Wednesday night.
    came to go to work Friday went to turn them on and nothing at all.
    The back wiper works ok and the front washers still squirt.
    i have checked every fuse in the car and they are all ok.
    The only thing I haven't checked is relays because I don't no what is what. Under the bonnet next to the battery there is 3 relays with the fuses and don't no what they do.
    There is also some relays behind the fuses in the car?
    If anyone can help I would be much appreciated I don't want to buy a new motor if there is something else.
    Thanks Dan.
    Fossie
    Rhubarb Triangle
    3,961
    Have you got aftermarket xenons by any chance ?
    Ash187 and sliced like this.
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Apr 2013
    I have Xenons yes but what has that to do with windscreen wipers?
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    I think he means, do you have HID kits installed? Some kits have been known to blow the wiper motor and thus stop your wipers from working.
    Oct 2012
    Warrington, North West
    959
    As above if its aftermarket xenon kit, there known to blow your wiper motor
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Dandavies View Post
    The question I asked was ' do you have aftermarket xenons ' and this is the reason I asked it !
    HID'S? WIPER MOTOR FAILED? DO YOU HAVE 'AUTO LIGHTS SWITCH AUTO LIGHTS ON YOUR CAR???
    Apr 2013
    i have a hid kit on my car yes sorry, but its been on since i got the car at christmas funny how they stop working now or does it take time?
    Fossie
    Rhubarb Triangle
    3,961
    Can do it at any time - sounds like you've been lucky up to now ! High frequency voltage spikes on start up kill the motor. There are HID kits out there that profess not to kill the motor but depends whether you are prepared to risk it. New motor is about £300 fitted I believe (but not sure ! )
    My advice is replace HID's with halogen ( or fit OEM ) and then replace wiper motor. If you try and replace wiper motor first then it will most likely go again !
    Have you got self-levelling sensors and headlamp washers ? These should be installed to stop dazzling oncoming drivers and are (slowly) becoming a requirement for MOT.
    Apr 2013
    what is OEM? no havent got self levelling or washers
    Fossie
    Rhubarb Triangle
    3,961
    Original Equipment Manufacturer. Or, in laymans terms about £1000 +
    Sounds like the guy that had the car before you did it on the cheap and not properly !
    Jan 2012
    SW London
    751
    There was a thread recently about a company that can fix the wiper motors for u when they do stop working in such an event. Cant remember the name of them sorry
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Apr 2013
    Ok thanks no problem I've put normal bulbs back in now and going to the garage for them to fix it. What's the best bulbs to put in then that are bright and won't affect the wipers in the future.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    Osrams or Philips are good
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Fossie
    Rhubarb Triangle
    3,961
    Yeah - Osram Nightbreakers or Philips Diamond Vision.
    I use Osrams
    Mar 2011
    137
    Hi Dandavies,
    Your wiper motor was broken because of your aftermatket HID.
    The are 2 solutions:
    - New Wiper Motor £300
    - Fix your broken wiper motor £45
    (there is a company that repair the wiper motor)
    If you seach in the forums you will see that there is some special HID for Audi A3.
    This HID will avoid the wiper motor problem.
  1. A3 Windscreen wipers
    By RevoKev in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2005, 10:55
  2. Windscreen wiper motors....
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2005, 10:02
  3. Lifting windscreen wipers when washing!
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2005, 12:59
  4. Clever windscreen wipers - or bust?
    By imported_katetodd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2004, 19:58
  5. Special Needs Windscreen Wipers
    By AndyMac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2004, 12:08
