AH FabricationsEM Tuning
Thread: 7 speed dsg ?
    Jul 2011
    216
    7 speed dsg ?
    Was it possible to get the 7 speed dsg in the s3 ? Been speaking to a friend at work and he has a A3 1.8t BE and it has a 7 speed dsg . how come the 1.8t had a 7 speed dsg then ? Thanks
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,607
    Jul 2011
    216
    Ah thanks. So whatys the benefit of having a 6speed wet clutch opposed to a 7 speed dry clutch then
    _G_
    _G_'s Avatar
    Jul 2011
    869
    The 1.4 and 1.8 are considered lesser models so to make them nippy Audi added the 7 speed. Personally I wouldn't touch the 7 speed dry clutch with a barge pole as it has way too many problems. The 6 speed wet clutch is still the best IMHO.
  1. Update on the new 7-speed DSG gearbox
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2008, 10:09
  2. DSG Fault A3 8P - Clutch temperature monitoring & Transmission Input Speed Sensor
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th June 2008, 18:54
  3. 7 speed DSG
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2007, 23:35
  4. Different Speed ... same engine 2.0 tdi dsg
    By n3cr0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2007, 00:34
  5. Very low speed behaviour of DSG
    By A4_2point4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2005, 08:52
