Badger5Chris Nott
Results 1 to 26 of 26
Thread: smoke!!!!
    Mar 2013
    44
    smoke!!!!
    Hi guys, yet another thing! Had glow plugs put in it! But still lumpy start up from cold and also Smokey! On tick over doesn't smoke but when pulling away there is a grey/blue smoke! And also when boosting there is abit but not alot! Its a 2.0 tdi 140! I'm hoping its not injectors, but im kinda thinking it is... Can anyone shead some light on it?
    Feb 2011
    Plymouth
    1,147
    remapped?
    Mar 2013
    44
    Nope completely standard! Also on start up its lump and almost on 3 cylinders! Also black and white/blue smoke on start up, but this is the only time its black! Just read another thread about the tandem pump, about the seal breaking down and mixing fuel and oil! Could this be a posibility? Going to take the fuel filter off tomoz and check the colour!
    Feb 2011
    Plymouth
    1,147
    I'm not really sure, only had mine 5 months so don't know a huge amount about them. Although they all smoke blue black and white, I wouldn't really worry about it too much. Diesels are known for just simply "working" they can sound like a bag of spanners when there is nothing wrong with them.
    I'd suggest keeping an eye on the oil level more than often and if it goes down pretty quickly there's a leak somewhere and it's mixing.
    I also think there was an injector recall to, but don't know a huge amount.
    Mine was quite rough until it was mapped where its now a lot smoother, puts out enough black smoke to fill a small room every time you boost though haha
    Mar 2013
    44
    I see! What's cold start up like on yours?? Is it lumpy? And looking at getting it mapped anyway, bit don't want to put the money in if the injectors are gone! :/
    Feb 2011
    Plymouth
    1,147
    starts pretty much after the first crank, best starting car ive had. can sound like the cambelt is slipping somedays which is when it sounds like a bag of spanners but its fine once it warms a little more.
    Try finding a dealer that does a 30 day money back guarantee and see if it makes any difference to it.
    Jan 2012
    SW London
    794
    What glow plugs did u have put in? Oem?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Mar 2013
    44
    I think the plugs were genuine Audi but not sure! and yeeeh this almost sounds on 3, but after a second or two settles down! Just don't know where to look next... :/
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    if not mistaken blue smoke = turbo change..., if you think its injectors which mean the car will be running lean therefore... but you have stated that it starts up fine .. just clean them injectors using an ultrasonic cleaner mate they would turn as good as new just get some new seals before you go one and check other sings... try putting it on VCDS
    Feb 2011
    Plymouth
    1,147
    Blue smoke = burning oil.
    However, diesel has a lot of oil in it anyway.
    It certainly does not mean turbo change, there is many things that could be causing oil burning even things like worn piston rings. You only really need to worry when it's drinking excessive oil and you have plumes of blue smoke out the back instead of black
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    Quote Originally Posted by Sevv View Post
    say what now? how do you do this? im interested
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Mar 2013
    44
    From cold its starts lumpy and not very good also quite abit of smoke (all colours)! But when warm it starts on the button! Its not plumes of smoke the smoke isn't a strong blue colour like a whitey bluey colour! Only smokes when turbo kicks in but if you rev up and hold at a constant rpm the smoke comes as it revs up and goes when held on constant! I'm running some injector cleaner through it atm and seeing how it goes! The turbo is noisey and even in previous garage visits this has been noted! I'm going to keep an eye on the oil level aswell!
    Cheers for the advice
    Jan 2011
    Australia
    1,316
    Quote Originally Posted by Ash187 View Post
    just buy an ultrasonic clearn they are like 30-60 pounds put some water and additives leave it for 30 mins and take them out all the 8L boys do it including myself when i serviced the 8P last friday...
    @smurfworth : as for the blue smoke on a 'petrol' would mean ur turbo is knackered so excuse me if i thought it be the same.. check seals possibly too
    Mar 2013
    44
    Does this work on the 8p though? Because they had dodgey injectors anyway didn't they? Its a big job to get them out aswell! :/
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Rather a big job on the 140 BKD engine... You'll also need the correct tool to re-seat the injectors and DTI gauge to reset the injectors once back in place... I wouldn't advise it unless you know what your doing
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Mar 2013
    44
    Yes its a big job! Haha has anyone done this to the 8p and had good results, or is this just a 8l thing that might work on an 8p? Don't wanna do it if its not gona change anything! :/ I have to say its getting better with the injector cleaner! Hopefully will cure it! Just odd how it only smokes when the turbos boosting! And only at the start of the spool not right the way through!
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Have you scanned your car with VCDS? Has it ever gone into limp mode? What sort of noise your turbo is making?
    VCDS USER
    Jan 2011
    Australia
    1,316
    I have done it to my 8p2 with a bwa engine code also carbon clean the inlet its not that big of a job its riht there but as mentioned u need the right tools ... to date i have no issue and thankfully no errors on vcds or the sort can even do it to the fpr
    Mar 2013
    44
    Been advised to fit a temperature sensor! And to be honest all the symptoms add up to it! If it was a dodgey injector it would go into limp mode straight away! Which it hasn't... I will clean the inlet thanks for the advice! Every little helps! Haha and the turbo is just more noisey than I would have thought it to be! On run down its loud and in the service history, over the the last 2 years this has been noted! Thanks
    Jan 2011
    Australia
    1,316
    Quote Originally Posted by cal 7888 View Post
    everyone should clean there inlet at least every year once as it will cause sludge build up inside the engine... im sure we all know what happens next.... it will also cause random judder as if u have a dodgy coil/ spark
    May 2012
    York
    241
    I used to have this problem, I had a bent conrod and car was pretty much on 3 cylinders
    Jan 2011
    Australia
    1,316
    Quote Originally Posted by Bramley View Post
    was that cause of the sludge ?
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    Not familiar with that engine code, it is petrol I take it?
    Op is asking about the 2.0tdi BKD engine. The injectors are inside the rocker cover, they are PD injectors and increase the pressures to thousands of psi by an extra fuel rocker layout and fuel is supplied in head. They are not as simple as petrol injectors and are more involved to remove and replace!
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    The injectors aren't that hard to change once you've got the rocker cover off, there's a single bolt holding them in! It's a little bit diddly & new seals must be fitted every time you remove/replace the injector unit.
    Things to do:
    1. Get the car on VCDS to check the torsion value & adjust the cams as required (search the forum for how)
    2. Clean the injectors with Diesel Purge (again, search the forum) it works 100x better than in-tank additives.
    3. Check your oil level & what spec oil you're running.
    4. Check the oil breather (PCV) located in the cam cover, if this blocks the engine produces too muck crankcase pressure which in turn forces the turbo seals to leak oil into the exhaust (hence the blue/white smoke. If it is blocked you can't replace the breather it's a whole new cam cover required - crap VAG design!
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Mar 2013
    44
    Apparantly it can be the air flow sensor aswell still gona clean the inlet!
  1. Smoked Rear Light Lenses for 2003 A6 Saloon
    By cliffcartwright in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2003, 14:28
  2. Smoking Kenwood Stereo!!
    By Naresh in forum In-Car Entertainment
    Last Post: 4th October 2003, 00:01
  3. A3 side repeaters smoked
    By FrOgR in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2003, 08:02
  4. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  5. Clifford Smoke Alarm
    By Moresauce in forum Other Brands & Models
    Last Post: 11th January 2003, 12:54
