Chris NottBadger5
Results 1 to 15 of 15
    Mar 2013
    158
    S3 faceflift "headlight range control defective"
    Hi there, this has been coming up since i got the car (private) and i now want to get it fixed.
    I've searched and found a few threads saying they just need to be reset through vag-com. Now my question is, has anyone got a definite answer for this?
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    320
    do you have a vcds cable? if so, look at this Ross-Tech: VAG-COM: Xenon Headlamp Adjustment
    +incoming MY15 S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Mar 2013
    158
    I'm afraid I don't have nothing like that
    Oct 2012
    Warrington, North West
    986
    Where are you located? Maybe someone local on here can use there's for some beer tokens?
    Mar 2013
    158
    Im in peterborough! Would be greatful if there was!
    Im also at Early Edition this weekend if anyone is going that could bring one!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    youll need the adaptation done on the headlight leveller unit, or a replacement, that is if your level sensors or headlights are all kosher
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Mar 2013
    158
    Could you explain a bit more mate? Is there anything I can do?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    has this car had the headlights retrofitted?
    Mods
    Mar 2013
    158
    NOpe is a 58 plate facelift!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    hmm probably jsut a sensor then time to invest in vcds!
    Mods
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    the range control module is usually 'defective' if 1 of the 2 sensors on the axles become faulty or if there is something wrong with the auto levelling control module.
    the sensors are located on the left side (passenger) front and rear axels
    when the car is first turned on do you notice the headlights go up and down before settling or does it not do anything?
    the issue could be fixed with a reset using VCDS or it may indeed need a replacement sensor but the best way to determine what is needed is to get the car scanned with VCDS to show what the exact error is.
    if you wanted to have a look yourself you could always have a look behind the wheels and see if the sensors have their plugs connected and that they are attaached properly? the other thing you could do is take the sensors off and see if they move freely, to make sure they are not jammed in place
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Mar 2013
    158
    The headlights do not go up and down when the ignition is turned on!
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    had this a few weeks ago with mine, both headlight range & adaptation were giving DIS errors, along with no left\right or up\down movement! Audi replaced a sensor under warranty. Turn the lights on before you switch the ignition on to see if they dip\rise.
    2009 A3 SB 2.0T DSG S line
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Mine had this error soon after buying car. VCDS identified is as the front NS sensor which attaches to the wishbone.
    Dead easy to change. Sensor was about £70 from Audi.
    Also while having tyres changed, they found a slight buckle in the Front NS wheel. Which ties in with the duff sensor..
    If you are in Lincoln sometime, drop by to use my VCDS.
    Mar 2013
    158
    Thanks for the offer!
    looks like I may have to buy a vcds though
  1. 2009 S3 Headlight Range Control Defective
    By Slappi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2012, 14:25
  2. A3 8P Headlight Range Control Defective / turn this off / can I code xenon to halogen
    By thebedscompany in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2012, 17:12
  3. Headlight range control defective
    By Shabs in forum A8/S8 forum
    Last Post: 28th February 2009, 20:42
  4. headlight range control
    By kanievsky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2007, 15:57
  5. Dynamic headlight range control faulty
    By gav in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th August 2007, 07:53
