Sky InsuranceBadger5
Results 1 to 9 of 9
    Feb 2013
    Grimsby
    1,099
    Buying guide for the A3? 2.0 tfsi
    Hi, i have searched the forum but with no success.
    Is there a buying guide for the A3 8P anywhere (the 2.0 TFSI in particular , with optional extra's or faults to look out for or anything like that. There was quite a large guide in the 8L forums and wondered if theres the same for here.
    Thanks,
    JJ.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Check out mine in the classifieds...
    Feb 2013
    Grimsby
    1,099
    I will have a look but i only have like 4k lol, n looking for a quattro one for sure.
    JJ.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,072
    I bought a 2.0TFSI quattro about 6 months ago ... here's what I found out:
    (a) 100% get the oil pickup pipe checked. They get blocked, and they are not always checked during services. If it gets blocked, it may kill your engine and the 2.0TFSI suffers with this. Mine was on a flatbed the day after buying it due to this.
    (b) Has it had the rev D dump valve fitted? Mine didn't and it failed.
    (c) Give it a good drive and check for diff whine. They do commonly make a reverse-like whine in 1st/2nd but it shouldn't be too loud. Did much research on this.
    (d) Get an AA inspection, they check for crash damage/repairs, resprays etc which is useful. AA are crap for other stuff as I discovered, but the inspection was good.
    (e) FSH doesn't mean it wasn't worked on by an idiot.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Feb 2013
    Grimsby
    1,099
    Does it come with a dump valve as standard? (dumpvalve is one that makes te psssst noise? and wastegate is a closed system one?)
    What is a Diff whine?
    Im not a mechanic in any sorts but im wanting to learn about servicing etc.
    thanks, JJ
    wuta3's Avatar
    Jul 2012
    1,072
    Quote Originally Posted by JJ.Foulds View Post
    thanks, JJ
    Yes it has a recirculating dump valve, and they revised it around 2006 I think to one that doesn't fail. Get your car checked out by a professional and u should be good.
    Feb 2013
    Grimsby
    1,099
    Quote Originally Posted by wuta3 View Post
    Well it will deffintly be a pre 06 one, and a dumpvalve was going to be my first attempted task, so i will replace it when i buy i think to stay safe. you can point me to a decent dump valve? thanks.
    JJ
    wuta3's Avatar
    Jul 2012
    1,072
    You just want the rev D OEM one from Audi/TPS.
    Feb 2013
    Grimsby
    1,099
    right thanks, and also i will be going for a quattro one with haldex, i understand this is important for it to be serviced. will there be a separate document for te haldex servicing?
    JJ
  1. Hid kit - Diy guide for the b6
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st August 2012, 22:56
  2. Any buying guides for a new member?
    By crazypainter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd June 2010, 21:00
  3. can you buy a single rubber seal for the rear brake piston ?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th May 2009, 09:28
  4. Replies: 3
    Last Post: 20th September 2007, 23:50
  5. Buying a A4 2.0TDI, go for the S-Line?
    By andyollie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th November 2005, 16:03
