Sky InsuranceAH Fabrications
Thread: Turbo oil leak
    Dec 2012
    49
    Turbo oil leak
    Hi anyone know if there is a reason how the turbo can leak oil after the oil in line and out line have been replaced. I have a leak round about the turbo with oil hitting the hot manifold or exhaust . The garage thought it was the oil lines which they changed but i still think its leaking somewhere (still a bit oily and have the burning smell). The car isnt running smoky and is an a3 2,0 tdi with only 43k on it.
    Lewis583's Avatar
    Mar 2010
    834
    Silly question, I assume they have made sure it isn't the cam cover gasket leaking oil?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Dec 2012
    49
    i doubt they have checked the cam gasket , the oil was seen at the back of the turbo, oil out pipe so they changed it but the leak was still there so they did the oil in line at the top but im sure it is still leaking there is oil residue around the top of the turbo were the inline is and there is enough oil leaking to leave the sump guard soaked
  1. Turbo oil leak from seal
    By Wilts in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2012, 15:34
  2. Turbo Oil leak, Easy Fix? (Pics)
    By RyanGolfGTTDi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2011, 15:26
  3. small oil leak possibly turbo seals tho
    By s4marsh in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2009, 01:59
  4. Oil leak from turbo inter cooler
    By john24susan in forum Diesel forum
    Last Post: 29th April 2009, 11:52
  5. oil leak from turbo pipe
    By john24susan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 09:57
