Badger5Chris Nott
    Dec 2012
    47
    20T rough start and burning fuel smell..
    hi guys
    Noticed this week that when I'm starting the car of a morning its. Taking longer than normal, and sounds rough for. Few seconds.
    Iv also noticed a burning fuel smell, if I'm out the car when first starting?
    Any common issues like this? Or any ideas?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    lambda sensors
    Dec 2012
    47
    Quote Originally Posted by MrLapou View Post
    lambda sensors
    Cheers mate ill have a look. Will this be the cause of both issues?
    Expensive fix?
  1. Burned oil smell, rough idle, loss of low end power, sloshing water
    By Stevie170 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th March 2013, 11:59
  2. 99 2.5 TDI - engine cut out and now won't start - timing issue? fuel pump?
    By mattupnorth in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2012, 10:43
  3. 2.0T FSI rough start up and misfire for first 2 seconds ???
    By ahed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2012, 20:54
  4. Cold start problem and expulsion with smell burning white smoke
    By Variante in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 21:01
  5. Replies: 12
    Last Post: 19th May 2004, 11:06
