Chris NottVolks Autos
Results 1 to 8 of 8
    Jan 2013
    2.0tfsi in the garage!
    So i've taken my 57 plate 2.0tfsi quattro feeling sluggish. Advice on here suggests it's most likely the diverter valve. Having spoken to technician working on the vehicle, he says it can't be, due to diagnostics showing boost pressures are fine. Could it still be the diverter valve or is he right? Cheers again!Clarkiey
    Jan 2013
    159
    Valve is around £50 if I recall correctly.
    My S3 was very sluggish, fitted a forge DV and its like a super car now!! They are £199 or so though!
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    561
    Ok i might be wrong here but surely reading the boost figures would only work when out driving in the car when the system is boosting up ? unless he went out in it ?,if he has done it while ticking over with diagnostic it wouldnt show anything
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Jun 2011
    138
    Quote Originally Posted by mmalh0151 View Post
    £48 here Audi Vw VAG 2.0TFSI Type D Diverter Valve/Dump Valve - FR&R Tuning| MAHA Dyno Rolling Road Tuning| Stage 1, 2 & 3 Engine Performance Upgrades - (Powered by CubeCart)
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Jun 2011
    138
    what fault codes did it show?
    Previous
    olethalb's Avatar
    Aug 2012
    314
    if boost levels are fine it would suggest not the DV
    i'l be looking at HPFP follower and pump drive lobe condition, again these can be measured on block 230 VCDS and view requested rail pressure vs actual
    this is all assuming the car has had regular servicing and coilpack recall done
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Perhaps the MAF. Easy to check, with it unplugged... if the car drives the same then it's prob goosed...
    However when unplugging and starting engine it will pull a fault code, which will need vcds to reset.
    Keep us posted...
    Diverters can be had for a lot less...i.e. eBay item # 321101812754
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    That's the old revision with the rubber diaphragm need the revision D
  1. Please help me even the garage can fix my A3
    By OliS in forum General Technical / How To
    Last Post: 22nd May 2008, 16:42
  2. Back from the garage :happy:
    By Jampublic in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2007, 18:20
  3. Cars in the garage now! woohoo
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2007, 16:25
  4. Car is in the garage
    By Donald_MacIver in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2006, 14:31
  5. New toy in the garage
    By marmite in forum General Chat
    Last Post: 8th October 2006, 06:27
Tags for this Thread
