Sky InsuranceAH Fabrications
    Apr 2013
    Question 2004 Audi A3 3.2 fault codes
    Hi to everyone on the forums, I have the above and have been getting faulty MAF codes for the last few weeks, I have had the MAF sensor changed twice, it will drive perfectly for two/ three weeks and then the MAF fault code will come up again, last night I also got the following Mass air flow sensor(G70): signal too low, Bank 1: Camshaft A(intake):Retard Setpoint not reached (Over Advanced) and also Exhaust Gas Temp Sensor 2 Bank 1 (G448):Electrical Malfunction, once I clear the codes down it drives right and may do so for a while and then the MAF fault comes up again, I'm not very technical and it has been in to two different garages to try and solve but to no avail, I love the car but am starting to think its time to get a new car, can anyone help, advise. Many thanks
    Apr 2013
    Aberdeenshire
    590
    [QUOTE=Jamandsut;1841118]Hi to everyone on the forums, I have the above and have been getting faulty MAF codes for the last few weeks, I have had the MAF sensor changed twice, it will drive perfectly for two/ three weeks and then the MAF fault code will come up again, last night I also got the following Mass air flow sensor(G70): signal too low, Bank 1: Camshaft A(intake):Retard Setpoint not reached (Over Advanced) and also Exhaust Gas Temp Sensor 2 Bank 1 (G448):Electrical Malfunction, once I clear the codes down it drives right and may do so for a while and then the MAF fault comes up again, I'm not very technical and it has been in to two different garages to try and solve but to no avail, I love the car but am starting to think its time to get a new car, can anyone help, advise. Many
    standard air filter ?
    Apr 2013
    Yes it's not been modified in any way
    Dec 2012
    Hordnean, Hampshire
    157
    Check out this thread for similar info - Engine cut out, ECS & ESP lights on
  1. audi A4 found three fault codes
    By dplovin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th October 2012, 12:49
  2. audi a3 8p 2.0 tdi 2004 fault codes, help!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2012, 12:16
  3. audi a3 1.8t fault codes?
    By quattrosport14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2010, 16:30
  4. Audi a6 fault codes
    By gt-ne in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th August 2006, 13:14
