Volks AutosJMB Retrofits
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Solviken
Thread: Led canbus Error 2008 A3
    Apr 2013
    9
    Hi
    I have a Audi A3 Sline quattro 2008 model, the last pre-facelift model. I have just upgraded to new LED bulbs in my DRL lights, bulb type BA15S P21W. With a can-bus resistor almost same kind as this one OBC Resistor Fix Leads for LED 382 P21W | eBay
    But i am still getting can-bus error inside the car. I have read somewhere that some of the audis are more sensetive to can-bus error, is this possible?
    Since i cant get rid of the can-bus error, is it possible to turn of the can-bus message in VCDS VAGCOM?? If so where in the program?
    Thanks in advanced for your help
    Apr 2013
    9
    Anyone?
    Jun 2011
    Wellingborough
    1,170
    Hi.
    Yes you can switch the Error off in VCDS.
    You need to recode the headlights. when i am home later today i will put a picture up to show you how.
    you will need to take that resistor out tho and then code it in.
    Trups
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Apr 2013
    9
    Quote Originally Posted by t8ups View Post
    Hi.
    Trups
    Thank you! Would be great if you could help me with that
    t8ups likes this.
    Jun 2011
    Wellingborough
    1,170
    Here you go.
    Go to 09 CE. Then long coding, then byte 21 and make the coding look like this. once this is done press do it and if the warning box pops up press no.
    then you need to clear the error codes and hey presto.
    Pull the sidelight holder out and hide it behind with the halogen sidelight still in like this picture
    You DRL will be full brightness in the daytime, then when you do sidelight and xenon they will dim down.
    Try that, let us know how you get on.
    Trups
    EM Tuning Lighting.
    Apr 2013
    9
    Sorry for late answer! I have been som busy at work i havent had time to fikkle with my audi. But today i tried! and it didnt work. or the error on the bulbs is gone but now i got an error on voltage
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    This sucks.. cause i dont want to have those ugly halogen lights in. But having an error in the dash is insanely irritating!
    Anyone have a solution?
    Apr 2013
    9
    Nobody?
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    I just put some led drl bulbs in my S3 , it come up with errors on dash , I opened VCDS and changed the setting and errors have gone
    Apr 2013
    9
    Quote Originally Posted by Yonner View Post
    DAmn... i just got error for voltage supply unit when i did it... Maby im just unlucky :P
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    I did at first mate
    Apr 2013
    9
    Mine didnt dissapear.. drove around with it for a week.
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    Did you change coding ? On byte 21
    Apr 2013
    9
    Yep i did!
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    did you change the light type? in the drop down box and clock do it?
    Apr 2013
    9
    Yeah. i Changed it to Xenon With led. Thats when the car noticed that i didnt have a voltageregulator for led in my headlights.
  1. 382 p21w LED without errors
    By Goththug69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2013, 00:29
  2. Heat Resistant 501 LED Sidelights (error free)
    By A4_MaJiK in forum General Technical / How To
    Last Post: 8th October 2012, 15:22
  3. Quality LED No error plate lights?
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd August 2011, 09:32
  4. LED canbus sidelights flickering
    By S3_Jacko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2010, 16:58
  5. 2008 Audi A4 SE - No LED light option!
    By Kyoshi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th January 2008, 16:06
