Sky InsuranceJMB Retrofits
Results 1 to 12 of 12
    Aug 2010
    160
    stumped on this one
    on my a3 140 the anti-shudder valve had stopped working which is a common fault so I replaced the part and its working
    but I still get a horrid shudder on shut down. now this happens 98% of the time only maybe 4-5 times its not made a shudder on shut down I have taken it two darkside and they carnt figure out why its doing it and neither can I. I have replaced fuel filter cleaned inlet manifold out replace seals checked its working on shut down everything I could think of do you guys have any ideas as me and darkside have no idea what to do with it
    May 2012
    York
    241
    fuel pump??
    Aug 2010
    160
    why would or could fuel pump cause this?
    Sportback owner
    Apr 2007
    France
    496
    Bigal, are you 100% sure that your new anti-shudder valve is working properly? If it really cuts off the air, the engine should stop immediately. The only reason not to stop is if there is a source of oil getting into the intake manifold. Hope this is not that case, but I would certainly check the valve again.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    TDI140's Avatar
    May 2011
    1,364
    Was the oart brand new or did u buy second hand if its second hand u need to buy a new part as they made a different part number as the old ones were faulty so the new one has been strengthened
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Aug 2010
    160
    brand new from eurocarparts with a nice 30% discount.
    its working I popped the pipe off and looked in when I switch the engine off and it closes for about 2-3secs then opens.
    don't see how oil could get in had everything checked over no oil in fuel or anything.
    all I could think when I watched it close was is it closing quick enough? could it close to slow and leave you with the shudder
    Aug 2010
    160
    Sportback owner
    Apr 2007
    France
    496
    Bigal, you are right to worry about ASV closure speed. As far as I know, the flap is spring-loaded to stay open, and the motor has to force it to close on switch off. Any unnecessary friction or low voltage, or bad contact may indeed cause it to close too slowly. If you can find another BKD engine to look at, you might be allowed to pull off the pipe and compare. When a diesel is told to stop by having its fuel injectors shut-off, it will try to scavenge any oil (or fuel) it can find from the whole intake system, and therefore try to run-on. If by chance the intake system is contaminated by oil residue, or oil leaks from the turbo, then this oil will be happily sucked into the engine on switch-off. Causing a slight run-on if the ASV does not do its job well, or perhaps quickly enough. Good luck.
    Aug 2010
    160
    could this be the battery not supplying enough voltage? I have tested the battery with a multimeter and all is good but when I turn the car on and the radio or mp3 is on and lights it all cuts out for a second the other days I do the same and nothing cuts out at all
    Sportback owner
    Apr 2007
    France
    496
    Trot around to your nearest auto battery shop or local garage and ask them to test the battery with a load-tester. That should give you a good indication of the general health of the battery. It is a worry though if there is an electrical cut out at any time. Get the shop to check on battery terminals and grounding points for corrosion, and possible loose fuse(s)/holders too.
    TDI140's Avatar
    May 2011
    1,364
    Quote Originally Posted by bigal23 View Post
    same one i bought so it didnt fix it, u need car plugging in mate wont figure it out u til its plugged in and diagnosed
    Aug 2010
    160
    the asv works fine and is not faulty car battery is good connections are all clean.
    tdi140 I plugged the car in to a friends vcds and I have two faults one is egr as I have deleted it but not mapped it out and the other a glow plug 3 fault, there is a couple of others but there to do with the fact I have xenons but without the auto levelling s come up with two faults for that.
    am lost with, I did have one idea could the injectors be leaking slightly and its running on from this slight leak?
  1. can someone explain this one??
    By ollyste in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 19:45
  2. Replies: 11
    Last Post: 28th June 2006, 22:35
  3. Dealers? Any one used this one?
    By steeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2005, 11:25
  4. unwanted xmas gifts on ebay - check out this one
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2005, 21:50
