EM TuningMonster Motorsport
Results 1 to 8 of 8
Thread: Wheel Alignment
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Wheel Alignment
    Hi all,
    So, finally getting the alignment sorted on my A3 after fitting my coilovers. Taking it to a local place that uses the Hunters 4 Wheel Alignment system. This is the first time I've actually had the alignment done properly instead of just having tracking done, so I've a couple of questions.
    What sort of figures should I be looking at? My car's my daily so I don't want it set up for being fastest out of the corners on a track.
    Below is what S3Alex was running at some point last year when he got his alignment done (hope he doesn't mind me using the photo). Would this be fine for everyday? I just want something that I can take in and say 'This is how I want it.'
    Thanks in advance
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Anyone?
    May 2012
    York
    241
    Cant change the camber without adjustable arms can you??
    So the main thing youd be looking at is just the toe, so they all want to be pointing forward. Right????
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    It's just the front camber that needs adjustable arms, the rear can be adjusted, I think.
    May just print the above report out and say I want it as close to that as possible. Can't be bad if a 500bhp S3 is running it
    klauster's Avatar
    Jan 2007
    Leeds
    1,140
    where abouts in Leeds did you take it fella?
    www.SubZerosystems.co.uk - IT Consultancy
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Surely you're best off just letting them adjust it to the manufacturers recommended settings that they'll have on the system for your chassis?
    I could be wrong here, but aren't S3's all quattro's? If yours isn't a quattro then there might be a difference in how it's set up. In which case if yours isn't a quattro (I'm not sure if it is or not) then those settings might be wrong for your car.
    I'm prepared to be corrected here, I'm just guessing at this.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Quote Originally Posted by klauster View Post
    Embarrassingly I'm still yet to get it done. Waiting 'til pay day on 16th and then booking it in at Station Garage at Castleford as that's closest place to me that uses the Hunters system.
    Quote Originally Posted by danb986 View Post
    Mine isn't quattro, but never thought about that. I'm gonna speak to them when I finally get it booked in anyway, see what sort of specs they say it should have.
    Feb 2011
    Plymouth
    1,135
    Heres mine if it helps, FWD. Not really sure if its good or bad, rear wheels were real cambered tho, This was done about a month after H&R 50mm springs were fitted
  1. 200 for wheel alignment?!?
    By imported_shkwav in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2007, 19:10
  2. Wheel alignment in Scotland
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 16:54
  3. Tracking/wheel alignment
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2005, 10:17
  4. AMD Wheel Alignment - Had it done ? Comments please
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th April 2005, 18:57
  5. wheel alignment
    By JayBeeS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2003, 16:57
