Volks AutosEM Tuning
Results 1 to 8 of 8
    Apr 2013
    South Wales
    19
    A3 2.0 TDI problems.
    Hi all, Just wondering if you kind people could help me out with two problems i have with my A3.
    1, Car seems to shake when stationary and also judders to a start from cold with a puff of white smoke, once warm runs great like any other car, but still shakes when stationary.
    2, Rear washer doesn't work found out that its leaking underneath, maybe a loose connection (pipe loose)? Is this a common fault heard the rear pipe gets blocked?
    BKD engine if that helps?
    Thanks in advance!
    Boon's Avatar
    Sep 2012
    South East Kent
    346
    1,
    Dual mass flywheel
    Engine mounts
    Timing
    Injectors/injector wiring loom
    Fuel
    Fuel filters/pumps
    Air filter/sensors
    2,
    Take the whole rear end interior apart to find joins/splits
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    May 2012
    York
    203
    Mine was doing this and it was a bent conrod!
    Nov 2012
    123
    Joee your car has the same symptoms as mine. Let me know if you find out what it is.
    Apr 2013
    South Wales
    19
    thanks for the reply's, hope it's a simple fix! Get it checked out soon.
    With the rear washer i think its just the pipe come apart from the bottom/side of the bottle? as when you press the stalk screen wash just shoots out the bottom/side of bottle. (where ever its connected).
    Apr 2013
    South Wales
    19
    Quote Originally Posted by heap1000 View Post
    Will do indeed, started a new thread in hope someone has fixed these problems by now and will come along with the answers we are looking for! hopefully.
    Apr 2013
    South Wales
    19
    Bump, pump pipe done! But this juddering is annoying not excessive but still annoying when stationary, anyone?
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    715
    Does the engine revs up by itself when stationary?
    Mine used to rev from time to time up to 1100rpm and back to 8** quickly. The coolant temperature sensor G62 was faulty.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
  1. tdi problems
    By maxiking in forum Diesel forum
    Last Post: 31st October 2005, 10:59
  2. '03 A4 1.9 TDI 'Problems'....
    By imported_timcoupe in forum Diesel forum
    Last Post: 4th October 2005, 22:25
  3. '03 A4 1.9 TDI 'Problems'....
    By imported_timcoupe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2005, 08:42
  4. A3 2.0 TDI Problem Number 1
    By DaveS3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2004, 21:49
  5. Post here 2nd -- A3 2.0 TDI problem
    By DaveS3Turbo in forum Diesel forum
    Last Post: 30th April 2004, 21:12
Tags for this Thread
