EM TuningChris Nott
    Apr 2013
    Lots of Fault codes including turbo overboost!!
    I recently had the engine light come on in my 2005 2.0 tdi DSG (140hp) with 120k on the clock. So I took it to the garage to see if they could diagnose it for me and came back with several faults including...
    • All 4 glow plugs out (I guessed that anyway)
    • 16618 Boost pressure regulation limit exceeded (overboost condition)
    • 19559 Motor for intake manifold flap malfunction (P3103)
    • 16346 Control module sporadic 014 defective
    • 00332 Control Circuit for Tank Flap 007 - Short to Ground
    • 01176 - Key: Signal too Low - Sporadic
    Additionally there were a few other faults that were related to the supply voltage - lower limit exceeded, caused by the battery dying in the cold.
    The one that concerns me most is the boost pressure one (16618). The car has absolutely more than plenty of boost in the mid range, but when you boot it out of a slip road etc it will go into limp mode until the car is restarted. I notice that when the turbo kicks in and gives you that big boost (say between 20 - 40mph), when you take your foot off the gas, sometimes it makes a whooshing noise. Is this normal?
    What could be the most likely issue here? Could it be simply sticky vanes, a leaky pipe / seal or am I looking at a new/recon turbo?
    Also, does anyone have any thoughts on those other problems? Am I perhaps best to cut my losses and trade it in, or blow a couple grand in getting it fixed?
    Thanks.
    26,720
    Welcome to the forum.
    Well some of them are well known, but the boost issue is more than likely the turbo vanes yes.
    Whereabouts are you located?
    Don't think it will cost a few grand to fix tbh, looking at those depends on module fault but I can probably sort most of if not all of them location dependent of course.
    Apr 2013
    I'm located just between Lincoln and Grantham. I spoke to Audi about all these faults who advise me that to fix all of these faults I'd be looking at around £2k+ VAT inc labour.
    26,720
    Ping me a PM & we can talk about this as I'm confident we can sort for less.
  1. A4 CAB FAULT CODES ANYONE??????? 1.8 TURBO PETROL
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th September 2010, 11:06
  2. Turbo Overboost
    By welshdragon in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2004, 07:57
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
