Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Chillout
Thread: Vcds expert required
    Apr 2013
    Aberdeenshire
    590
    Hi I was wondering how easy it is to add the lock and unlock beep to my 2005 a3 3.2 v6 I have looked at doing this before but I am bit worried about messing things up I would also like to add follow me home lights if possible would much appreciate help from a vcds pro.
    cheers
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,393
    Follow Brodster On Twitter Add Brodster on Facebook
    Its a doddle mate. Will take a competent VCDS user minutes to give you the unlock/lock beep feature..........if you have the facility available within the module. I know the newer cars have it as its one of the most popular things that people want doing.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,169
    Visit leeds2592's Instagram Channel
    I've done the lock/unlock beep on mine.
    If I remember correctly, you go through 46 Central Convenience, Long Coding, can't remember which Byte (might be Byte 7) but click through them until you find the option Locking/unlocking confirmation (horn) via remote control. Tick those boxes and save. Pretty simple but if you're worried, just take a note of what you clicked so you can easily just change it back if its wrong.
    Also, here's a little guide to follow for the Coming Home lights cominghomelights - Audi Retrofit
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Apr 2013
    Aberdeenshire
    590
    Adding the beep
    Quote Originally Posted by leeds2592 View Post
    I don't suppose anyone could talk me through adding the beep
    Oct 2012
    Warrington, North West
    986
    He basically just walked you through it then, it doesn't get much easier
    Apr 2013
    Aberdeenshire
    590
    Easy
    [QUOTE=Mikemc;1841321]He basically just walked you through it then, it doesn't get much easier[/
    yes your correct I am a plonker it's simple
    thanks everyone
    Brodster likes this.
    Oct 2012
    986
    [QUOTE=Chillout;1841328]
    Quote Originally Posted by Mikemc View Post
    thanks everyone
    It took me a few mins to realise you can click the different "bytes" so your not the only one!
    Apr 2013
    Aberdeenshire
    590
    Funny one
    [QUOTE=Mikemc;1841656]
    Quote Originally Posted by Chillout View Post
    I carried out the coming home lights mod as per guide however at first it didn't work so I disconnected the link from the earth drove to my mums then it worked however if I unlock it they don't work all the time but they work every time when locking just wondered how they were meant to work ?
    Oct 2012
    986
    Double check your coding and is your wire earthed? As it only needs to be touched once to turn on as I found out on here, I then taped it up
    Apr 2013
    Aberdeenshire
    590
    My wire isn't earthed anymore seems to be the leaving home lights only work if you haven't locked the car within a set time just unlocked it now and it worked. However if I unlock it then lock it without opening the doors they go out immediately once locked I think they are meant to work like this ?
    cheers
    Oct 2012
    986
    Yea mine do that I think it's normal
  1. VCDS Expert required
    By vroomtshh in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd October 2012, 22:29
  2. Key Coding with VCDS Report , Expert Required!!
    By Blacky165 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2012, 15:46
  3. VCDS help required in Bedford after RNS-E and Bluetooth retrofit
    By satj in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2012, 09:10
  4. RNS-E EXPERTS REQUIRED
    By Andy Shipton in forum Satellite Navigation
    Last Post: 9th December 2009, 17:09
  5. brake expert required.
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2008, 08:51
