Monster MotorsportVolks Autos
Thread: cambelt
    Mar 2013
    44
    cambelt
    Just thought I would enlighten the members on my complications today! I took my 2.0 tdi to the garage a few days ago for a cambelt change and mot, I hadn't heard anything so went to check on it today! When I got there the car was in a bay with the bonnet up being worked on by the mechanic! I spoke to him, and he explained how lucky I was! basically wen he went to take the tensioner off, it undun with his fingers... Castestrophy avoided in my eyes! as I stood there relieved he then went to put the new tensioner on, it didn't tighten.... :/ this means the thread has gone in the head... Has anyone else had a similar experience?
    MacrosTheBlack's Avatar
    Mar 2008
    Kent
    204
    A few days for a cambelt change and mot??? Surely that should be done the same day you had it booked in?
    Is it a garage you trust? What's to say they've not accidentally stripped the thread themselves?
    Hope you get it all sorted soon.
    26,754
    Oh dear, someone has not used a torque wrench & just tightened as hard as they can & I'd say multiple times to cause the thread to be chewed up to that degree, but its a little strange they've had it 2 days & they only just got to the tensioner?
    Quote Originally Posted by MacrosTheBlack View Post
    Exactly my thoughts tbh, there is no way if the car went in ok & the thread was stripped to the point the bolt wouldn't do up, would it run on our roads without going tits up way before, now based on my knowledge, I don't believe it was stripped before they got it, I'd be questioning this seriously as that's a rather big problem unless they can tap a slightly larger bolt, that wouldn't affect the tensioner etc at all.
    Also, to be sure is it the aux belt or cam tensioner?
    Mar 2013
    44
    Yes I trust the garage its owned by one of my dads friends garage, and always use him! I never book there just drop the car off and wen its done its done! Haha, he used a torque wrench as I watched him do it! But I just wondered if this is a weak point on the engine and people have experienced it before!
    Thanks for the replies
  1. S3 Cambelt
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2004, 09:44
  2. cambelt done.
    By 603ELO in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 14:09
  3. Cambelt Tensioner - Know Issue???
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 07:56
  4. Cambelt replacement interval
    By cyberdude in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2003, 19:07
  5. When to change cambelt??
    By Joules in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th April 2003, 14:25
