Volks AutosMonster Motorsport
    harvz's Avatar
    Dec 2011
    60
    Question do all a3's indicate low oil?
    Hi just serviced my a3 8pa and wanted to know will it indicate if my oil is low? I did check it regularly after service but still would be reassuring
    It doesnt indicate if my wash fluid ect is low as i dont think it has a steering ecu.
    It has a full display tho, not just indicator lamps. I have added a pic to show u what i mean
    The top half of display which is black in pic, is for radio. Bottom half indicates gear change and middle dont do anything on my car just tells me the car needs servicing or which door is open.
    The car dont even tell me temperature outside... which i find stupid saying its an audi with a/c and even standard vauxhalls carry this on all models.
    Also if i did want to enable outs temp to display or low washer fluid level or mpg indicator would i need to fit a steering ecu? or would i have to fit steering ecu + all sensors?
    harvz's Avatar
    Dec 2011
    60
    update: I managed to enable DIS with help from tom and his VCDs. Just need to install a new wiper stalk with functions to control trip comp.
    Can any1 advise how to do this? with pics if possible.
    I also found out the car has climate control and wanted to add a digital climate control unit and get rid of the analogue one. I also need from someone if they know if this is a straight swap job?
    Crunching The Gears
    Apr 2012
    Invergordon Scotland
    407
    Can't help with your question, but what do you mean by gear change indicator?
    Does it tell you when to change up/down at the right time? Thanks
    Mods so far...
    LED Interior Lights, Front splitter, Cruise Control.
    Puddle/ Footwell Lights, LED number plate and side lights.
    75% Window Tints, MY11 Lights, Black Optics Grill.
    MFSW, Leather trimmed Grab Handles. CH/LH Lights
    JL Audio, DAB radio
    Vinyl wrap wing mirrors
    harvz's Avatar
    Dec 2011
    60
    Quote Originally Posted by Cozza McA View Post
    Yeah that's the one... Just to help others without dis and a full display it can be enabled with Vcds!! I had my car 2 years and asked this forum before and had responses of u can't do it.
    Anyone know answers to my questions?
    May 2012
    RETFORD, NOTTS
    1,753
    You can do anything with a little time money and our friend Google!!
    Have fun with your new cc and dis functions :D
    Regarding your question, there's a sequence can be activated to cycle through the warning symbols on the dis, try pressing buttons after you first start the car, mines the lleft Bbutton near the clock
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    harvz's Avatar
    Dec 2011
    60
    Quote Originally Posted by @udi A3 View Post
    Thanks for your help Tom top Guy... Yh I had a fiddle with the trip comp, can't believe my basic car had so many functions that just wasn't enabled
    Thanks for all the help with coding the car all up and enabling cruise control too
  1. Low Oil - Quick advice needed
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2007, 20:57
  2. Low Oil Temp And Very Low Water Temp...?
    By rick the spud in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th May 2007, 16:49
  3. Resetting The low oil warning light.
    By Biggles in forum General Technical / How To
    Last Post: 19th January 2007, 09:08
  4. A4 B7 2.0TDi Low Oil Level Warning Light
    By stedes in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd November 2005, 18:31
  5. Low oil?
    By synthdood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2005, 16:19
