Monster MotorsportEM Tuning
Results 1 to 16 of 16
Thread: Brake Imbalance
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Brake Imbalance
    Bit if a weird one, that I've not seen as a mechanic.
    I'll start from the beginning...
    Fitted S3 front brakes, noticed they were binding. Checked on brake tester, and left caliper effort was slower than right, but overall effort was actually higher. They also binded a bit.
    Stripped out pistons, which were fine. Cleaned and lubed sliders, obviously bleed brakes.
    Binding was fixed, but still left side was slow to apply.
    I was thinking a collapsed flexi maybe, un likely, but would explain it.
    So put original brakes back on for now as I've been off work last week.
    Today, out of curiosity, I put car in brake tester with standard brakes on.
    Exactly the same results, left side applies slower, but with higher overall effort.
    Both standard and S3 are imbalanced enough to fail mot. Bit both feel fine under braking. Doesnt pull at all.
    So this has ruled out calipers, carriers, flexis.
    Anyone ever had anything like this?
    I'm now down to master cylinder, steel line, valve (assuming it has one) on bulkhead, ABS unit.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Bump....
    Anyone?
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    729
    Dirty brake fluid? Or as you mentioned a collapsed/pinched brake line.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Jul 2012
    Essex
    183
    Are they new brake calipers or previously used?
    If new then ask the supplier for replacements. If used then you'll have to take them of and rebuild them.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    They are used.
    Already stripped pistons out. Calipers are fine.
    The fact it does exactly the same with original calipers, and S3 ones means it can't be flexi, as they are different for calipers. Unless both left flexis are faulty.
    It can't be the caliper, unless with left calipers are faulty.
    Under airline pressure, pistons move the same, left pistons don't require more air pressure to move.
    Brake fluid is brand new, 5.1. And wouldnt affect just 1 wheel.
    I appreciate the input, just already eliminated all suggested. Which in fairness, is why I'm stumped!
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Brake testing equipment maybe faulty?
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Nope. You can physically watch the piston on the ns pump out slower when the caliper is off.
    Still driving fine.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    567
    I'd be tempted to put braided hoses on. Bit of an expensive stab in the dark tho..
    What did you use to clamp the brake hoses? My have damaged inside the hose without any signs on the outside of the hose.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    A brake hose clamp.....
    Same I use anytime I work on brake lines.
    That was my first thought. And if it only did this with the S3 calipers, I'd have bought a new flexi right away.
    But it does other with standard calipers and hoses.
    Which would mean I broke BOTH left flexis....
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Have you tried purging the ABS pump unit with VCDS & done a proper bleed?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Apr 2012
    UK, Portsmouth
    567
    Quote Originally Posted by Rom View Post
    Funny you say it like it was obvious. I've seen people use sockets on mole grips.
    Tried blowing air through the flexi? Might have got a bit of poo in it? Calliper isn't leaking from the join?
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Had the brake hose issue before, they can develop a small tear on the interior laminate that acts like a one way valve, either holding or limiting brake fluid flow. Had this on my front right last year.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    I've not done a vcds bleed. Didn't know you could.
    Has been bled with a vacuum / pressure bleeder.
    There's no leaks no.
    I've not blown through the flexis, but they bleed the through OK.
    I've got it in my head it's not a flexi, as it does the same with standard brakes, and standard (not s3) flexi as well. So would mean both flexis have identical faults.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    infernalzen's Avatar
    Feb 2012
    29
    i bet its the lh flexi hose.
    +the system is putting more px down the line, to compensate for it not producing the same braking effort initialy.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    So you think both left hand flexis have the same fault then?
    It can't monitor pressure or braking effort from what I know.
    A master cylinder exerts x amount of force / pressure for a give pedal movement. It's just a piston pushing fluid.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Lewis583's Avatar
    Mar 2010
    833
    Can you not swap flexi hoses left to right and see if the fault follows?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. Front brake pads
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 16:30
  2. Brake Fluid
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 23:39
  3. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  4. S3 Brake Upgrades - not Porsche/Brembo
    Last Post: 25th January 2003, 17:05
  5. Brake Pad Upgrade?
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 05:19
