Chris NottSky Insurance
Results 1 to 8 of 8
Thread: Run Flat Tyres?
    Aug 2012
    68
    Run Flat Tyres?
    I need to replace all four tyres which are 225 40 18 but am unsure if i can fit run flat tyres on them as i was told you need tyre pressure sensors fitted? my car is also a quattro and im getting part worn tyres will this affect handling in any way?
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,553
    Tbh i,ve never liked runflats and i,ve seen a few bad examples of the tyre spitting from the side walls ,why not just get a set of really top tyres and have a spare in the boot ...
    Feb 2011
    Plymouth
    1,150
    I think there was a lot of BMW alloys cracking when they decided to fit run flats as a standard option. Although I'm not 100% sure that was the whole reason behind it.
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,553
    I,ve seen a few on different cars ,my boss get about a year out of falken runflats before they go ...but then again it is a brabus...
    Jul 2011
    Bucks
    161
    Stupidly hard ride according to most people. Also I have had one puncture in over 20 years of motoring so they are pretty pointless IMHO
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,553
    I,m the same box ,touch wood lol
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Suspension not set up for ROF's.. Plus your insurance will have to be informed as these are not manufacturer spec.
    Had ROF's on my Mini, but I still carried a space saver wheel. They worked okay, but like any tyre if, it has a blow out, tyre will not be able to drive on. Stick to normal tyres and carry a spare...
    Aug 2005
    West London
    850
    You shouldn't fit run-flat tyres to a wheel rim not designed for them. The rim on a run-flat wheel has an EH+ (extended hump) profile and a normal wheel rim uses an H profile. A non run-flat tyres bead will fit onto a run-flat wheel rim but the other way around bead wont seat correctly and although it may hold pressure it definitely couldn't be used with low pressure like a run-flat is designed to.
    Now:BMW 530d M-sport tourer. Then:Lava Grey A3 Sportback S-line 2.0TFSI Quattro, S-line Special Edition, Xenon Plus, Leather, Light and Rain Pack, Interior light Pack, Bose, DVD Nav+, Bluetooth, Multifunction wheel,Cruise, Heated Front Seats, Folding Mirrors, Rear Parking Sensor and some other bits.
  1. BOOM! Pothole flat tyre!
    By Greig300 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2011, 21:47
  2. Running odd tyres on a quattro.
    By sonnyjim in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2010, 01:59
  3. Run Flat tyres
    By AudiMaz in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2009, 10:24
  4. Retro-Fit Flat Tyre Warning Indicator
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2008, 11:55
  5. Flat Tyre Indicator
    By AUDIA3QS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2008, 11:13
