Sky InsuranceBadger5
Results 1 to 7 of 7
    Mar 2013
    Advice needed...
    I have recently remapped my 2008 s3 and the clutch is now slipping in the higher gears. I know there has been alot of posts here about replacing clutches but I was wondering if some1 could advice me on what would be the best but not too expensive. I won't be doing anymore upgrading to the car if that makes any difference.
    Jan 2011
    northants
    165
    theres a few to choose from but i fitted a helix organic to the other halfs leon cupra tdi
    it wasnt cheap but it can take the torque and feels slightly heavier as its a single plate clutch biting/grab feels as standard
    Mar 2013
    Thanks for the reply, did u replace the flywheel at the same time.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    Quote Originally Posted by L11wne View Post
    What Stg or power/torque are you running?
    If you want to retain the DMF,then the Sachs organic is the best choice,but will need a bit of gentle bedding in.
    Other than that,the Loba/Sachs SMF setup is excellent,and would cope with over 400lbs.
    Mar 2013
    It's the bluefin stage 1 software. I thought it would of been a good idea getting it done but turns out to be a expensive 1
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    The stock clutch is basically pretty poor,and may or may not manage Stg1 torque(around 310-320lbs) without trouble,but at some point it will give up.
    All of the replacements weigh in at around £1k,when you include the flywheel and labour and the dreaded VAT.
    Mar 2013
    LOBA Motorsport Single Mass Flywheel and Sachs Clutch Conversion S3 8P (06-12) - GNJ Motorsport
    Would this website be the best/cheapest place to get it from? Thanks for all your help
  1. Advice Needed Pls
    By RAV in forum General Chat
    Last Post: 25th February 2004, 12:29
  2. Advice Needed Pls
    By RAV in forum Diesel forum
    Last Post: 25th February 2004, 11:56
  3. Advice needed on changing
    By Mike_Wales in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 14:07
  4. A3 / S3 advice needed
    By MsK in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2003, 11:38
  5. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
