AH FabricationsBadger5
Thread: V6 coolant loss
    Apr 2013
    Aberdeenshire
    595
    V6 coolant loss
    Hi all I replaced my engine coolant temp sensor a week past Thursday and have been topping up with antifreeze most days so I thought I had air in the system however for the last 2 it has been ok I have probably driven 30 miles each day with no drop but today I checked it and it has dropped with no evidence of leakage I have also notice that I can wiggle my sensor around but it doesn't leak
    any thoughts .
    no mayo so hopefully the head gasket is ok
    27,123
    It can take a little while to burp itself fully, so keep an eye on it, top up & see if it continues, if so then a pressure test on system is best option at 1-1.5bar overnight to see if it drops.
    Apr 2013
    Aberdeenshire
    595
    This car makes me paranoid after the update I notice oil around the drivers side output shaft on the gearbox and then a noise from the rack when turning left at parking speeds its a bit of a money pit and its only done 35 k
  1. Coolant loss again - going to Audi
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th July 2009, 14:16
  2. my coolant loss story
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2009, 12:42
  3. Coolant Loss! 1.8T
    By jcp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th May 2008, 22:43
  4. Coolant loss changing Thermostat?????
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2007, 22:43
  5. 2.0 TDi Coolant loss <again> - Get it checked out!!
    By adamhill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2006, 16:20
