Sky InsuranceEM Tuning
    Apr 2013
    40
    Rear windscreen washer not working
    57 plate 08 shape a3 sport 3door 1.6 i can hear the motor on the rear but no fluid is coming out any suggestions? Thanks guys
    Yiddogaz's Avatar
    Nov 2012
    Tyne and Wear
    31
    Fluid pipe may have come off or be leaking and it's corroded the motor. Take the trim off its two bolts and 7 clips just pull mine was really hard to get off but it did eventually.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    Get a needle and poke it though the dot bit where waters supposed to come out of, something could be stuck in there. Also check if you've got wiper washer and not just water in there as if its 0 degrees outside them obviously it's gonna be frozen
    26,747
    Peter this has been discussed to death fella, please always use the search function before opening threads.
    Now, just pop of the rear washer plastic cover that is over the jet piece, then pop of the small dual holed jet plastic part, then operate the washer to see if water comes out, if it does, then do as per Sliced has advised & stick a needle into the jet holes.
  1. Rear window washer not working?
    By Jonezy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2013, 15:26
  2. Rear window washer not working (water scoosher)
    By cshy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2012, 12:33
  3. Rear windscreen washer not spraying on A4 sline Avant (56)
    By marballs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th May 2011, 19:44
  4. Rear wiper washer not working? 2004 8p
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2011, 16:40
  5. Reaer windscreen washer not working
    By Monsoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2008, 16:19
