Results 1 to 14 of 14
Thread: V6 Problem
    Feb 2013
    21
    V6 Problem
    Hello, anyone come across this? 2004 3.2 V6 when I turn the engine off the cooling fans continue to go, I don't mean that they stay on for a while then turn off, I mean they only turn off when they've drained the battery of every last amp of power.
    Thoughts please?
    Scott
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by scottmachine View Post
    Thoughts please?
    Scott
    If it was my car I would check for a stuck relay as the contacts could be welded shut once you find the relay I would tap it firmly this may be enough to separate the contacts and then you could replace the relay as this would rule out the relay coil being supplied with 12 volts from the ecu failing this I would suspect the radiator temp sensor on the bottom hose on the radiator I would also check it with vcds.
    Feb 2013
    21
    Temperature guage is reading normally which I guess gets its reading from the sensor on the bottom hose. Any idea where the relay would be? Thank for the reply.
    No fault codes with VCDS
    Apr 2013
    Aberdeenshire
    592
    i am not sure tbh but I think the relay would be under the bonnet in the fuse box however your car has 2 coolant temp sensors one one the block and one on the rad I have seen a few post that the r32 golf has a fan module not sure if our cars share this part . I think fuse 54 is the fuse to remove under the bonnet to stop the fans meantime but don't drive like that I also would have thought if the module existed on our cars was faulty it would show codes .
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    It's the fan control module which has died. Our R32 had the same problem about a month ago and I tracked it down to the fan control module which sits underneath the battery on the passenger side.
    I got one off eBay for £30.
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by RobinA3 View Post
    I think it would be under as the fuse box in the case of the a3 just to be different I suppose
    Feb 2013
    21
    Well since the battery is in the boot I'd hope its under the fuse box.
    I'll have a look and report back.
    Apr 2013
    Aberdeenshire
    592
    I would disconnect battery first the fuse box is secured by Torx in the middle of the box when you lift it it disconnects loads of connections hope you find it I have googled with no luck.
    Feb 2013
    21
    Don't suppose you know the part number? One that I found Audi A3, TT, VW Bora, Golf, Lupo, Polo, Seat Radiator Fan Control/ Relay Module | eBay doesn't look like its for the later model.
    Apr 2013
    Aberdeenshire
    592
    Do you have vcds because when your coolant temp sensor fails fans run flat out found this from info from vw (http://sandbox.enjoybeing.net/veedub...self_study.pdf) should be identical but I have also seen info that says the module is integrated to the fans I will have car on ramps soon so I will have a look.
    Aug 2012
    Essex
    73
    I have a similar problem on my V6, but mine do turn off. Someone advised me a while back that its the air con rad fans that come integral to the air con rad. The fans on mine are on constant full whack if the a/c is on.
    Feb 2013
    21
    Looks like the module is part of the fan, which is only available as a modified kit from Audi, comes with the 2 fans and a new cowling. I'll update once I've done it.
    Apr 2013
    Aberdeenshire
    592
    £££££ sounds costly
    Feb 2013
    21
    Most things Audi are. I'll post prices etc once its done.
  1. Transmission Problems
    By MisterD in forum General Technical / How To
    Last Post: 3rd February 2003, 13:23
  2. Ooo eck I've got a problem!
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2003, 13:12
  3. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
