Monster MotorsportChris Nott
Results 1 to 11 of 11
    Dec 2011
    North East Scotland
    17
    engine problem s3 2012
    Where to start , right been running stage 1 shark for around 4 months no problems at all then added the Amd cai kit and a week later i get the emissions light on !!!!!! Flashed the ecu back to standard as didnt want to be putting added stress on any parts
    So called audi assist the boy plugged in his computer and said it was running lean and recommended an hpfp so ordered one and fitted it this week along with a cam follower since i was removing the pump anyway and then flashed back to stage 1 after going for a test drive and then checking everything was fine , so all was good pulling like a train and running fine then emissions light comes on again arggghhhh.
    Now was wandering if anyone had any ideas what could be causing it ???
    Could it be that the car was mapped when standard and now having added the hpfp and cai be causing the map to run lean and need adjusted to suit the mods added ?????
    Any help suggestions appreciated
    Cheers Baz
    Jul 2010
    561
    Need to get it scanned to find the fault code first, know anyone with a VAGCOM?
    Dec 2011
    North East Scotland
    17
    Fault code is p2177
    _G_
    _G_'s Avatar
    Jul 2011
    869
    http://wiki.ross-tech.com/wiki/index...9/P2177/008567 - check for these symptoms.
    If it's running lean it could be the hpfp.
    Dec 2011
    North East Scotland
    17
    Ok will get it checked and see, fingers crossed its something simple like a pipe leaking .
    Nov 2004
    Tonbridge, Kent
    912
    Check the MAF sensor as it could have been damaged when fitting the intake.
    It's unlikely you will have an issue with the HPFP on a 2012 car.
    Ben S3 8P3's Avatar
    Jul 2012
    Bury//Manchester//Leeds
    313
    Let us know what the result is!
    Ice Silver Audi S3 (8P3) https://www.facebook.com/benjamin.n.long
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    If the CAI has an oiled filter, chances are that's your problem. The oil from the filter will slowly coat the MAF & cause all kinds of incorrect readings.
    The flash back to standard MAP & then return to the remap will have delayed the ECU in flagging any problems as the car will still have been in an 'adjustment period'.
    A quick scan on VCDS or the dealer system should easily be able tell you if the MAF is providing a correct reading or not.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    AFAIK,the filter is not oiled.....what you need to do is to take it back to whoever fitted it,and get them to sort it.
    Ben S3 8P3's Avatar
    Jul 2012
    313
    Could it not be a mapping issue?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    It really needs to be taken to either whoever did the work or a decent tuner and logged to find what the problem is.
    If its running lean there is a serious problem.
  1. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
  2. Diesel Engine problems
    By sinbadfury in forum Diesel forum
    Last Post: 16th May 2006, 15:26
  3. 2000 A6 2.8 Quattro engine problem
    By bullcell in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th August 2005, 23:02
  4. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
  5. Engine Problem - 2.6 V6 - possibly ECU Fault -
    By imported_k15hvc in forum Classic Audi Forum
    Last Post: 11th July 2004, 21:40
