JMB RetrofitsChris Nott
    Apr 2013
    40
    REAR Knocking sound!!! HELP
    Ok 1st full day of owning my 57 plate 2008 shape 3 door 1.6sport i noticed when going over any bumps in the road or speed bumps the rear of the car would make a knocking sound someone said it could be the stone guards i havent a clue about cars i managed to get my head under the car i saw the 2 guards and they move up and down with very little force is this the problem? Thanks guys
    Aug 2012
    Aberdeen
    42
    I would have said a broken spring at the back
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    742
    Most likely the stone guard, which are just plastic and clipped to the rear suspension arms. Check if they're loose, if they are just pull them off!
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Oct 2012
    30
    I'd say stone guards,I've had to take mine off
    JPK
    May 2012
    278
    if the sound has some compression noise with it change the rear trailing arm bushes. That fixed mine.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
  1. S3 knocking sound coming from engine - pls help - getting worried.....
    By Denty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2011, 19:40
  2. HELP!!!!STRANGE KNOCKING SOUND
    By norfolkaudi in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2010, 10:54
  3. Knocking sound from rear
    By monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2009, 21:48
  4. 2.6QS rear knocking noise, Help !
    By BLP in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2008, 12:45
  5. Calling all brembo owners Knocking Sound pls help
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2007, 15:55
