Volks AutosSky Insurance
Results 1 to 14 of 14
    Mar 2013
    Leicester
    6
    Emmision Control System!!
    Hello Guys!
    I'm new to this forum and also a new owner of a 2006 Audi A3 2.0 170 TDI Quattro - so please forgive me for my stupidity
    I've got an issue with the Emission control light coming on, its been on for about a week now and there's no difference in performance, however the car does seem to have fairly high consumption (Topping up £60/week). I've read through a few threads and they all say the same thing - get a VAGCOM done. Is there anyone close by that would be willing to help me out??
    I thought maybe it was something to do with the DPF (this warning has come on a few times now) but this warning goes away after a 20min drive down the A46.
    Thanks in advance guys!
    26,720
    Welcome to the forum.
    Sounds like a dpf regen being done based on your post, ideally you should get someone with vcds to check levels & then force regen or take for a nice spirited but safe drive on the motorway or dual carriageway for an hour.
    Mar 2013
    Leicester
    6
    Thanks for the reply dude!
    I've been up and down the motorway a few times and this sorts the DPF out. I had the emission light come on with the DPF a few weeks ago - took the car for a spin and the DPF light went off and then a day later the Emission light.
    This time the Emission light just stays on and the DPF will come on and go away after a little cruise.
    Anyone with VCDS, willing to help me out??
    Mar 2013
    Leicester
    6
    I'm REALLY worried now - took the car for a drive on the motorway - doing about 60mph to force a regen and the glow plug light came on and the car went into limp mode!!
    Going to take the car in to get it diagnosed, fingers crossed this is not going to be expensive to fix.
    Anyone shed any light on this??
    Oct 2012
    Warrington, North West
    953
    Where are you located?
    Oct 2012
    953
    Just checked your profile, go in the vcds users map and look around your area. Couple of beer tokens usually do the trick for their service
    plymouthaudi's Avatar
    Jan 2012
    88
    Had the same problem went into limp mode and will stay like that till you either force regen it like nhn says or you do what I did and have it removed and remapped. Works like a dream and the best ever mod I have done. Specially if you only do town driving like I do the dpf can get a right pain in the arse. Plus I get better mpg and a quicker car.
    A3 8P 2008 2.0 TDI 170BHP S Line
    :-Remapped to 210BHP
    :-Pressed Number plates
    :-Xenon Lights 4300K
    :-Footwell Light Retrofit
    :-LED Interior Conversion
    :-Stainless Exhaustf
    :-DPF Removed
    :-RS4 Bucket Seats Retrimmed
    :-Boot Tool and Air Compressor Build in the making
    :-Drilled and Grooved Discs and Brembo Pads
    :-Callipers Painted Red
    BlackVue DR380G-HD Fron camera
    Jan 2012
    88
    Also worse case with having the regen done it could still not work due to it being too full and a new dpf is required and that's £2000. This is what happened to me so a remap and removal was £500 so that was my choice each to there own tho.
    :-DPF Removed
    Mar 2013
    Leicester
    6
    Thanks for the replies guys.
    I'm planning on getting the DPF removed but can't afford it just yet so I'm hoping the force regen works!
    plymouthaudi - where did you get the remap and DPF removal done? £500 seems a good price. I've been told it will cost me about £650
    Thanks again guys!
    Jan 2012
    88
    There is a company in Plymouth where I live. It was a Longlife exhaust franchise but they went on there own I can't remember the name they are now, they fabricate exhaust etc and use angel tuning packages for there remaps. I had it done about 18months ago and still going lovely. I will try and find out what they are called if your interested.
    :-DPF Removed
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    682
    Get the car checked on VCDS, soda law says the DPF sensor has failed & needs replacing.
    Have a look at your sensor (located at the back left of the engine above the DPF - has 2 pipes & an electrical connection on it), if it says 'Made in USA' its almost certainly your problem.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    harvz's Avatar
    Dec 2011
    60
    Quote Originally Posted by irfan.khalifa View Post
    Thanks again guys!
    If u in Leicester i suggest u got to nic from tuned n styled. tunednstyled.co.uk/. It will cost £399.
    Hes done my car and can sort out any sensor issues u have, i had exhaust sensor go and he replaced it for free with remap and dpf removal and egr disable
    Mar 2013
    Leicester
    6
    Well, got the car checked and the mechanic said its most likely the DPF. He gave me some Forte to put in the car and took it for a long drive but this didn't work!
    Spoke to the mechanic again and he said its probably the DPF sensor but it would be better to have the DPF removed.
    So got on the phone and now I've got the car booked in with Rick at Unicorn Motors to remove the DPF and EGR Valves and get the engine remapped
    Hopefully this should be the end of all the issues and warning lights!! - I'll keep you guys posted
    Mar 2013
    Leicester
    6
    Time for an update - DPF and EGR removed and engine remapped! I have to say Rick was great and very helpful. All warning lights and limp mode all gone and the car seems to drive a lot better.
    Only problem i have now is the clutch slips in the higher gears if i floor it - I need to change the clutch but don't know whether to go for the OEM one or an uprated one!
    Thanks for all you help guys
  1. Emission Control System Fault
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th December 2011, 17:54
  2. flashing emission control system light on S3
    By julians in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2009, 13:48
  3. Emission Control System Light
    By jumpers in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2008, 21:08
  4. Emission Control System light's on.
    By dkelly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2007, 10:02
  5. Emission Control System
    By migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2007, 14:50
