Volks AutosEM Tuning
Results 1 to 34 of 34
Like Tree7Likes
  • 4 Post By Cruiser89
  • 1 Post By Jameze
  • 1 Post By icekay
  • 1 Post By LEE69
Thread: How To: Fit Aluminium S3 Pedals
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,397
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Post How To: Fit Aluminium S3 Pedals
    Hey everybody!!
    Right… Well I have had these pedals sat around for ages and the other day I decided to fit them. I’m not an engineer or installer and could have got one of our guys to fit them but I decided to have a go and do it myself!! Thought it would be more rewarding that way. Anyway as quite a few people have asked how you do it, I documented the process.
    Just to let you know I have a 62 Plate Manual Audi A3 Black Edition (MY13). I’m sure the process is pretty similar for the Auto & DSG Gear box.
    Here we go:
    Step 1
    Take a look at your current setup and see if you have a manual or auto setup
    Step 2
    I started with the Accelerator as it’s the one that can take a little bit longer. So to the left of the pedal there is a hidden 8mm bolt. Using a small screwdriver just pull out the hidden panel to reveal the bolt.
    Step 3
    Using a long reach, you can easily unscrew the 8mm bolt. If you have access to a long reach magnet then it will make it easier to grab hold of once un-screwed.
    Step 4
    Ok so the next bit for some people is quite difficult but was surprisingly easy for my pedal. You need to pull out this connector to disconnect the pedal from the car. There is a red security tab that needs to be pulled upwards first. Just get your fingernail in the groove and pull upwards slightly
    Step 5
    Once the tab is pulled up you then use it as a little lever (push down towards to floor) this will open the connector so that you can give it a quick tug and it will pull out of the pedal
    Step 6
    This was the next step I found the hardest. Removing the pedal from the floor of the car. I used the new pedal as a guide and realised there was two flat holes either side. They both have clips that you need to disengage whilst pulling that side up. Picture below shows the location of them and how the clips look.
    Step 7
    So I started with the left hand side first. The carpet does hide the slits but push it down and you will see it. I used a big flat headed screwdriver for this bit. You push it into the slit and then push the handle to the right. At the same time you pull that corner up (Don’t be scared to use some force)
    Step 8
    Move on the right hand side and when you get the flat head in you just need to push and it will disengage. Pull that corner up slightly but not fully off. (I tried to pull it straight off but it wouldn’t budge)
    Step 9
    Now with the left hand side fully unclipped and the right hand side raised I twisted the whole pedal to the left and it just popped off. This was just the method that worked for me.
    Step 10
    You should then have an empty area like this
    Step 11
    Now this is a bad photo but it gives you an idea on what those metal round clips look like
    Step 12
    Next is the exciting part. Get your new pedal, line up the clips and give it a hard push down and the clips will lock in. You then have to push the pedal fully down into the space. I found that getting the bolt in at this stage helped with lining the pedal up with the floor. You then need to plug the red connector back in. Once you feel a click, push that red tab back into place to keep it locked in.
    Step 13
    Now admittedly I did my clutch and brake pedals before anything else and didn’t get any pictures of them off. But the best way to get these suckers off is with a trim tool. Start from the bottom to get the rubber lip off and then pull really hard at the top to get that badboy off! Don’t be scared to get rough with it
    Step 14
    You will then be left with a nice looking pedal like this
    Step 15
    Once everything has been fitted into place… Stand back and admire your work
    So here is the final transformation. The old rubber pedals to the new Aluminium S3 Pedals!
    Hope this How-To was useful and not teaching you to suck eggs!
    Any questions just shout!
    Tim
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi Bluetooth -AMI/iPod - RNSE Navigation Units - Cruise Control - Optical Parking Systems - DAB (Digital Radio)- Audi Factory Retrofits- Stolen Vehicle Tracking - In-Car Cameras- Genuine VCDS Cables
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Really great guide you have. I will be using this on the wknd to install my new pedals!
    Do you know if you can get a aluminium foot rest as well, looks odd without it?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Oh man, you've got me wanting to do this now!
    Is this the best price, £60 inc postage from the Czech Republic?
    Audi A3 S3 RS3 8P NEW pedals original genuine Audi pedals RHD, best price | eBay
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Quote Originally Posted by JRock247 View Post
    Well if it helps one person then it was worth writing!!
    Yes I want to get a nice looking Dead Pedal... May get my own one made. There is a workshop near our unit that does metal fabrication and tooling.
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Quote Originally Posted by A3Kent View Post
    Yeah I have heard this chap is pretty good for these pedals. I bought mine elsewhere but send him a quick message!
    reepers's Avatar
    Aug 2011
    Manchester
    110
    Wicked write up pal! (y)
    A3 2006 S-Line Sportback - 2011 Facelift Rear Lights - RNSe - Cruise - Bluetooth - S5 Alloys - Auto Dimming Rear View Mirror - Akoya Silver
    Future Mods:
    - Facelift "Dumbo" Power Fold, Auto Dimming Wing Mirros
    - Bi Xenon Headlights
    - Rear S3 Valance
    - Ish -
    Jameze's Avatar
    James
    Jul 2011
    Leeds
    505
    I remember this was the first mod I did (had the pedals before I had the car!). The worst part is definitely getting the accelerator off - it took lots of prodding and prising with some long screwdrivers to try and get it off, I was petrified of breaking it! The cable is easy to remove if you know to look for the tab - I'd read a few stories on here before I did it and some people said they'd broken their connector not realising there was a tab. It's surprisingly easy once you know to look for it!
    It's a must have mod in my opinion. It instantly transforms the interior!
    Cruiser89 likes this.
    Jul 2012
    Leicester, UK
    73
    Quote Originally Posted by Cruiser89 View Post
    this seller has 3 types of the dead pedal, maybe of interest to members
    AUDI A3,S3 & A2 ST/ST FOOTREST PEDALS | eBay
    zak151 likes this.
    Audi A3 2.0 TDi Sportback ¦ Phantom Pearl Black ¦ 16" alloys ¦ 58 Plate ¦ Acoustic Rear Parking System ¦ Criuse Control ¦ Interior Light Package ¦ Light & Rain Sensor ¦ Door Mirrors Auto Dimming and Folding
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Quote Originally Posted by icekay View Post
    I like the plain one to be honest!! Looks pretty good. He does mention about a Group Buy. We could perhaps organise one? I will send him an email now!
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    +1
    Plain one would be my preference too. Would be interested in the group buy.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Do they fit? If you look at the images on the eBay listing, they show 2 screws at the top and a screw at the bottom of the dead peddle, the images of the guide above show only one screw at the top.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    I thought you screwed it over the top of the existing dead pedal? It stops just before the existing top screw.
    Tempy's Avatar
    Aug 2012
    Kent
    148
    I used that very seller to buy my S3 pedals mate. I can definitely recommend him. My delivery took a while, but then I did order them just before Christmas. Genuine OEM product and well packaged. I couldn't find them cheaper anywhere.
    Great write up Tim. I wish I had this when I did mine as I broke my original pedals getting them out. I didn't realise they were clipped in and read another post on the forum that just said pull them up Oops
    Not a big deal, but would have preferred not to have broken them.
    Audi A3 8P 2.0 TDi S-Line 140CR 3DR | Full Leather S3 Dimple Heated Interior | Dual Zone Climate Control | Black Edition Grille | Black Edition Fog Light Grilles | Dension iPhone Kit | Heated Seat Retro-Fit | Titanium Alloy Refurb | Window Tints | Parrot Bluetooth
    Plans
    Remap
    | Reverse Parking Sensors | Who Knows Where From There
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Quote Originally Posted by Tempy View Post
    Thanks for this mate, just gone ahead and ordered a set
    Will be using this "How To" guide Cruiser so thanks for putting it together.
    Nov 2011
    top tip, dont do what i did and rip the wires out of the accelerator pedal plug lol
    coxy8329's Avatar
    Nov 2011
    Hampshire
    165
    Great write up. Fitted mine last weekend, from the same EBAY seller.
    The one thing (Step 5) I want to comment on. On my 57 sline the plug on the accelerator pedal had a grey clip that had to be slid down. It does latch in the down position (it takes a bit of force to do and took me a couple of attempts), in this position the plug pulls off very easily. When you push the plug back on the clip unlatches, locking the plug on.
    I also fitted a metal foot rest plate that I bought of Ebay from the seller mentioned earlier. I did need to counter sink and polish the plate. The plastic foot rest needs to be removed to fit the plate.
    To get it out.
    You undo one screw at the top of the rest and a nut on a stud hidden behind a circular panel behind the brake pedal.
    You then need to push it diagonally up and towards the front of the car, took a bit of jiggling to get it out.
    When it's out position the metal plate on the plastic rest, mark, and drill.
    Attach the plate with the supplied hardware, the supplied bolts are too long and will need cutting down.
    Refitting the modified rest is reverse of removal.
    Hope this help.
    Audi A3 Sline 170 2.0 TDI
    Mods Done
    RNS-E mkII fitted, Tinted Repeaters, Center Armrest,
    LED Interior Lights, Cruise Control, LED Number Plate Lights,
    VW fan windshield washers, S3 Pedals, Metal Footrest,
    DPF & EGR delete, Unicorn Remap, De-badged the tailgate.
    With DPF Without DPF
    May 2012
    West Country
    172
    Quote Originally Posted by coxy8329 View Post
    To get it out.
    I found getting it back on to be a complete pain, I even bought short flanged 10mm long
    stainless bolts and nyloc nuts for it but literally drew blood getting it back on as well as
    breaking a couple of the dead pedal clips.
    I put gloss black, reflective red and carbon effect vinyls behind mine to get the look in the picture.
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Nice... I like that carbon vinyl behind it.
    Hopefully it helps all those who use it
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    403
    Talking Pedals
    Here is my footwell went for the Audi rings with red insert
    The bolts with the fitting kit are far to long so you must shorten them as much as possable other wise you will not get the
    foot rest back on as it will sit to high and took me a while to refit
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Got my S3 pedals today from the Czech seller on eBay. Bought them last Friday so 4 working day delivery is pretty good.
    I will be fitting them following Cruiser's guide tonight or some time over the weekend and will get the results up as soon as I can.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    Quick question. I assume disconnecting the accelerator will not produce any error codes and I don't need to disconnect the battery?
    coxy8329's Avatar
    Nov 2011
    Hampshire
    165
    I didn't get any errors, and didn't disconnect the battery. Kept the keys out of the ignition until I'd completely finished.
    Good luck
    Mods Done
    Apr 2013
    Poole
    24
    I just fitted my pedals (same seller) using your guide. Aprt from my connector rab being different this guide was spot on and very helpful.
    kudos mate
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Quote Originally Posted by benclothier View Post
    kudos mate ������
    Awesome... Well done pal.
    Ahh you're in Poole too. If you need some toys then we're just round the corner :D
    Apr 2013
    Poole
    24
    Interesting. What 'toys' do you do? Lol
    Apr 2013
    Poole
    24
    Sorry just woke up. Im planning a few things in the near future so i may pop round. Cheers
  28. #27
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    791
    Ta for the guide, throttle pedal clip didn't want to budge at first, but they are on now
    Growing old is mandatory, growing up is optional
  29. #28
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,397
    Quote Originally Posted by LEE69 View Post
    Mine have been in a while and with such a simple mod still makes me smile when I see them :D
  30. #29
    Jackx1's Avatar
    Dec 2013
    Salisbury, Wiltshire
    64
    Had a quick go in the rain today, couldn't for the life of me see any type of red tab!
  31. #30
    MAD_Adamski's Avatar
    Jan 2009
    308
    Just did mine today was very straightforward took about 15mins as. Mentioned the floor clips were the worst part! Looks ten times better now! Nice Guide!
  32. #31
    Jan 2012
    367
    So just a word of warning, the facelift DSG dead pedal is a different shape/size to the manual (and the one I had on my ed 30 Golf DSG) so please check the correct fitment before buying.
    HTH
  33. #32
    Dec 2013
    120
    Quote Originally Posted by Biggy View Post
    Same here mate. Had to buy connector from wreckers and solder the wires back together. Lucky I got it all repaired in the same day. How did you repair yours?
    If I had this DIY to follow it wouldn't of happened back then lol
    Good write up
  34. #33
    Dec 2013
    120
    Quote Originally Posted by Jackx1 View Post
    You may have the grey lock tab which needs to be pushed downward like mine. Needs a bit of force to push down and once it's unlocked you can remove the connector from the black plastic part (don't pull from the wires or the cable harness).
    Use a bright torch to see what goin on down there.
  35. #34
    Dec 2013
    120
    I read somewhere to wait 15mins after turning engine off and removing key before disconnecting the accelerator connector from pedal. If it's not connected properly, you will get an error. ( I know this because I turned engine on when it was not connected )
  1. how to fit oem electric folding mirrors for a3-a4-a8
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2010, 17:28
  2. How to fit RS4 pedals?
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th February 2009, 01:19
  3. How to fit Coilovers
    By elucidate in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2006, 18:40
  4. How to fit a siren to my alarm?
    By imported_norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2005, 11:43
  5. Anyone fitted/know how to fit a Boost guage on a diesel?
    By evomaster3000 in forum Diesel forum
    Last Post: 27th January 2005, 18:13
Tags for this Thread
