EM TuningChris Nott
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Mr. B
Thread: s3 side skirts
    a3glenn's Avatar
    6th gear
    milton keynes
    94
    s3 side skirts
    hi
    will start post as so many do buy saying that they have been searching
    and cant find what they are looking for, I REALLY CANT FIND WHAT IM LOOKING FOR!
    i am trying to find the part numbers for the 3dr s3 side skirts, i can find lots for the sportback but none for the 3dr
    the only reason is that, i have phoned tps for a quote and im sure they are quoting me wrong, i would rather just give them the part numbers knowing i am ordering the right parts
    hope some one can help
    cheers
    27,126
    Why do you think they're quoting you wrong?
    a3glenn's Avatar
    6th gear
    milton keynes
    94
    well it may be me but as i see it, to fit 3dr side skirts you need to remove some trim parts (my car is an se) the trim on the lower rear quarter and the insert on the near to the bottom of the front wing, so the skirt fits in and the front cap fits,
    they are saying that the front cap is about £7.50 (the pic on etcka (sorry for spelling) looks like the part i take off.
    they also so say i need the rear quarter trims as well
    i thought that there was 4 parts each side
    long side skirt
    front skirt cap
    lower door trim
    and scuff trim in the door shut
    and 1 or 20 clips
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    944
    Sills : left 8P3 853 859 GRU
    right 8P3 853 860 GRU
    Wing caps : left: 8P0 853 579 GRU
    right :8P0 853 580 GRU
    Door edges : left: 8P3 853 959 K GRU
    right: 8P3 853 960 K GRU
    scuff plate : left: 8P3 853 491 K 01C
    right: 8P3 853 492 K 01C
    a3glenn likes this.
    jsosic's Avatar
    Mar 2011
    Zagreb, Croatia, Croatia
    172
    Quote Originally Posted by Snipe View Post
    Can somebody help me - what is a Scuff plate? Can you post pictures?
    If it's the plate when you open the door which says "S3", then I guess I don't need it because I already have S-line plate. Or do I still need it?
    a3glenn's Avatar
    6th gear
    milton keynes
    94
    thank you so much, now i can get shopping
    Apr 2013
    London
    135
    Are all these above parts needed for the S3 side skirts? Or just the sills??
    jsosic's Avatar
    Mar 2011
    172
    Quote Originally Posted by Big Pumpa View Post
    Yeah, there are even some screws and bolts that are needed beyond that list. I will post as soon as I got them.
    Also, one thing that's bugging me - there are no bolts in ETKA for the lower part of the side skirts, and each side skirt has 9 holes on the bottom side...
    How did you attach it to the chassis?
    Mr. B's Avatar
    Jan 2012
    Bristol
    944
    Tiger seal,don't get carried away with it
    jsosic's Avatar
    Mar 2011
    172
    Quote Originally Posted by Ironborn View Post
    Isn't the tiger seal too strong? What if I need to take it off after some time, without damaging the skirt?
    I would prefer some kind of mechanical nut/bolt type of solution...
    Sep 2012
    Cornwall
    106
    Quote Originally Posted by jsosic View Post
    I don't think a mechanical nut/bolt is an option mate. I assume you are talking about fixing the skirt on the underside to the car? An S3 has the facility to fix the bolts but an A3 doesn't so Tiger seal is what I used.
    jsosic's Avatar
    Mar 2011
    172
    Quote Originally Posted by A3-black View Post
    Yeah, I mean the underside of the car.
    Well, one could drill holes and fix the skirts with screws?
    And if I decide to tiger seal, should I try to make it waterproof - eg, not to allow water to enter into the skirt?
    Sep 2012
    Cornwall
    106
    Drilling the underside of the car wouldn't be the best way to go in my opinion. As I say I used the clips under the sills and the adhesive on the back of the skirt, then I put a small amount of tiger seal at each fixing point on the underside and its solid. Why do you want to be able to take them of? Is it to return the car to standard when you sell it?
    jsosic's Avatar
    Mar 2011
    172
    It's easier to paint them if the paint is for example scratched.
  1. Zender side skirts fitted few pics
    By concoursneil in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2004, 22:10
  2. S4 Avant NON-Body coloured side skirts
    By anthor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th June 2004, 11:18
  3. Zender Side skirts A3T
    Last Post: 15th June 2004, 19:12
  4. fitting oem votex side skirts to my 1.9tdi 2000 a4
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2004, 15:12
  5. S3 Side Skirts
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2004, 15:37
