AH FabricationsBadger5
Results 1 to 15 of 15
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    Fitting a ITG CAI on a S3
    Could anyone please tell me how long it would roughly take to fit the intake in question?
    mine turned up from a member today :D just wondered if I had time to fit it tomorrow after work as it quickly gets dark. Not had chance to pop the bonnet and work it out.
    It looks a simple job. Just plug and play? Is the airbox bottom half fitted in with rubber grommets like the engine cover also?
    thanks for any advise.
    Also I presume it's a easy enough job to fit the standard back on?
    Jul 2011
    217
    Heard the clip on the turbo pipe is a struggle
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by jonny1985 View Post
    is it a spring retaining clip like the one to airbox?
    Jul 2011
    217
    Not sure tbh use the search bar
    Sep 2012
    Nottingham
    16
    Took me about an hour to do mine, a steady plod at that, sipping tea and yapping to mates etc.
    The turbo inlet wasn't too bad, if you have flexy or pivot sockets its a breeze. It gets a bit right around the filter cone / last bend area and its worth taking the time to position the clips for max clearance. It's an easy ish job, just a bit fiddly as you'd expect.
    Mar 2013
    Leicestershire
    425
    Cheers Marc. Might just leave it as it will be coming off in a week or two again, then back on again.
    see what the weathers like lol
    Sep 2012
    Nottingham
    16
    No problem! It will be much easier when it's not dark - you're guaranteed to drop a clip or screw into the abyss if you try it in the dark, that's usual case for me anyway lol.
    336
    AmD charge £50+vat to fit their CAI which would imply about an hour.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    buy these mate Spring Loaded Hose Clamp Pliers - Fit and remove Clic and Clic-R hose clips | eBay and it wont be a struggle:]. Took me no more than 30 sec to take one off and put it back on when I was taking my car to Audi.
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Took me about 30 mins - most of which was spent doing the clip on the turbo up! Getting the old pipe off the turbo was quite tight as well and you have to pull harder than you would think (ooo er missus). Position the clips in the right place to access the bolts before you start doing them up - a little bit of thought saves shed loads of time!
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    GNJ_Motorsport's Avatar
    Jun 2011
    Lancashire, England
    645
    It is easy Corey, turbo pipe can be a pain but not that bad. We would charge an hours labour to do it.
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    That clamp tool Red put a link to would come in really handy for removing the oem clamp on the turbo pipe. I'm relieved the CAI came with jubilee clips! Much easier!
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    It took me around 40minutes, most of this time was spent trying to get the engine cover off lol, once that was off it was simple to do. Just a bit of hand squashing for the turbo pipe.
    Ibis S3 8P3 - Airlift V2 / S63 AMG wheels / RS3 Grill / Recaros
    Previous: Polo 6n2 20vt / S3 8L GT28
    Instagram: @bradraistrick
    http://www.audi-sport.net/vb/a3-s3-s...s3-thread.html
    Mar 2013
    Leicestershire
    425
    Quote Originally Posted by br20vt View Post
    Doesn't the cover just pull off? No bolts etc?
    Mar 2013
    Leicestershire
    425
    Ok find a couple how-to's for similar kits etc, happy days.
    Just before I get stuck in, does the standard spring clip off the turbo inlet (the one which causes the swearing lol) get re-used on the silicon joiner from the ITG kit or is it replaced with a jubilee clip?
    Reason is I didn't get a clip for that joint (it came assembled near enough), so just want to see if I need to go pick up some clips before I start taking it all apart.
    Thanks.
  1. Question about the ITG CAI iv fitted
    By Morells in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2013, 00:51
  2. Saves me starting a new thread - anyone selling an ITG CAI for S3?
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2010, 02:57
  3. ITG CAI development session - Initial impressions
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2010, 16:31
  4. Acronym madness: ITG CAI ON S3 8P
    Last Post: 27th February 2010, 14:10
  5. TID engine cover with ITG CAI
    By blackcruiser in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th December 2009, 23:11
