Monster MotorsportVolks Autos
Results 1 to 27 of 27
    Apr 2013
    Market Drayton
    2008 Audi A3 1.4TFSI Steering wheel swap, help please??
    Hi guys,
    I have a 2008 Audi A3 1.4 TFSI which currently has a standard round steering wheel on, i have bought a round multifunctional steering wheel off eBay which was taken out of the same model and year as mine...
    Will the wiring that needs to plug into this new steering wheel already be there tucked away?
    Will the airbag fit?
    And is it an easy and simple job?
    If anyone is local to TF9 and wants to earn some cash to do a proper job then drop me a text to 07920113019
    ive attached images of both the current steering wheel that's fitted now and the new steering wheel i want to put on..
    Cheers in advance!
    26,774
    Welcome to the forum.
    Forget it fella, your airbag wont fit bottom line.
    Also need to see what airbag fitment is underneath your current, as there are 2 types, ideally airbag needs pulling forward, pics taken of inside of current wheel to ascertain fitment for your airbag which is predominantly the expensive part unfortunately.
    Apr 2013
    Market Drayton
    Cheers for the help, i have taken the current one steering wheel off and the new wheel goes straight on but yes the air bag doesnt fit and looks like it needs the round type which is another £250 , i understand i need to change the steering wheel module as well which are £50 but i cant find the loom which is going to go from the module to the wheel if that makes sense?
    Cheers!
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by turneradam93 View Post
    Cheers!
    The steering module you require is more like £150 not £50 - part number 8P0 953 549 F. ONLY this version will work. The wiring loom is about £40 from Audi.
    I have a mfsw available that your airbag will fit if you're interested.
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    I have completed a similar change on my A3. I upgraded my SW for a 2009 MFSW and had to purchase a new steering ECU and harness for the airbag. MFSW cost £40 (eBay), Steering ECU £70 (eBay) and the harness was £42.70 from Audi. I did not have to purchase a new air bag as my old one fitted fine. You will also need to get it coded, be warned, I had no power steering, ABS, ESP for a few days while I found someone to code it all in.
    Good luck with the upgrade, if you get stuck PM me and I can help.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Shame you brought that steering wheel really, my steering wheel is practically the same as yours but has the normal air bag (non-round), so was a straight swap from my old steering wheel, no need to fork out for another air bag.
    Got my steering wheel at a bargin for £40 in perfect condition.
    My steering wheel (minus the S-Line badge)
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    As said, steering control module won't be as cheap as you think.
    Shame you didn't post this about a week ago, as I've just sold the module you need on eBay for £110.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Apr 2013
    Market Drayton
    Can you send me a picture of the steering wheel you have? If you know if one for £150 let me know, on eBay is £295
    Apr 2013
    Market Drayton
    Quote Originally Posted by JRock247 View Post
    I rushed into buying it, i think i best get it back on eBay again and buy one like yours!
    Apr 2013
    Market Drayton
    Quote Originally Posted by leeds2592 View Post
    I was looking at wrong moduels, there is one on eBay for £295
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Do you need one with an air bag? If not, see this:
    AUDI A5 A4 B8 3 SPOKE LEATHER MULTI FUNCTIONAL STEERING WHEEL S LINE A6 Q7 A3 | eBay
    Apr 2013
    Market Drayton
    No i dont need an airbag as i have the one thats in the car now.. That wheel is spot on but means ive got to spend another £450 for the wheel, harness and module...
    Apr 2013
    Market Drayton
    Any body want to buy the "new" steering wheel? pictured above... haha
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Chuck it up on the classifieds and on eBay, should sell it easy or try and find someone to swap!?
    Apr 2013
    Market Drayton
    If anyone has or knows to a steering module, steering wheel and harness for sale for a decent price then let me know, thanks for everyones help
    Fossie
    Rhubarb Triangle
    3,961
    His airbag will not fit that wheel !
    Apr 2013
    Market Drayton
    Mike, Have you got a picture of yours mate?
    Fossie
    Rhubarb Triangle
    3,961
    The steering module from Audi is about £180 without discount. This is the wheel I have which your airbag will fit :-
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    It will and does fit! I have a 2006 A3 with the same sline steering wheel as him and my air bag fitted perfectly into the 2009 MFSW as I pictured above. There are ONLY 2 types of steering wheel air bag, round for the newer wheels and the one pictured above, never seen any others.
    Why wouldn't it fit?
    Fossie
    Rhubarb Triangle
    3,961
    With due respect mate you are wrong. Look carefully at the picture of mine and the picture of the one on ebay.
    Then come back and tell me that there are only two types of airbag !
    I have considerable knowledge and experience with wheel and airbags as I fell foul of the complications three years ago.
    You should not advise people without knowing the facts as you could encourage them to waste money !
    I will award marks for a spot-the-difference competition !! ( I am speaking about fitment differences only, not cosmetic )
    Apr 2013
    Market Drayton
    How much are you after for it Mike?
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Apologies, I see they are slightly different in the size, looks like my image is for a 'shorter' air bag and yours is a 'longer' looking air bag. Am I right?
    I am sorry for miss-informing, looks like I to have been miss-informed!
    Fossie
    Rhubarb Triangle
    3,961
    I have sent you a PM.
    26,774
    Look closer Jrock
    Fossie
    Rhubarb Triangle
    3,961
    No probs mate. There are three differences :-
    1. The socket for the wiring harness is at 2 o'clock on mine and 4 o'clock on the other
    2. On mine there are two pins, one each side of the fixing screws, which are not on the other and,
    3. The angle of the fixing screws is much flatter than the other.
    The airbags are the same size but have different frames. That one on Ebay is from an A4. I know that because I have got one which I bought in error 3 years ago ! If you know of anyone with and A4 that wants one just let me know.
    EDIT : there is also another difference in fitting but it is difficult to tell from the photos.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Thanks for the info Mike. I will pop that in the knowledge bank for next time.
    Do you know what, I think I was told there are only 2 types by an Audi engineer when I was enquiring about upgrading my steering wheel, I could be wrong, either that or the retro fit people I also asked. Who know's, at least I now know the truth.
    I will be more careful the next time I 'attempt' to help someone.
    Thanks again.
  28. #27
    Fossie
    Rhubarb Triangle
    3,961
    Thanks again.
    You're welcome. You can now tell those who gave you the bum information what the real facts are !! lol
  1. Car steering wheels shaking help please
    By L3WJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2011, 21:46
  2. 1995 A4 1.8T STEERING WHEEL SWAP
    By holt1958 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2010, 21:21
  3. Audi A3 to S3 steering wheel conversion
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2008, 12:10
  4. Steering wheel swap? Info please
    By ITALIANJOB in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2005, 14:46
  5. Audi Sportback 3 Spoke Steering Wheel
    By chrisdavies00 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th December 2004, 13:19
