Chris NottMonster Motorsport
Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By maffew
  • 1 Post By NHN
  • 1 Post By MrLapou
Thread: CORROSION offside near arch/fender (with pics)
    Aug 2012
    Milton Keynes
    86
    Hi guys, just noticed this and I am pretty sure it wasnt there 2weeks ago (who knows, bad weather, last time I washed the car was a month ago and it definitely wasnt showing then) but have had the car washed now and its showing. I am assuming the rust was there, it has just spread.
    Anyways I have read that Audi give a 12yr corrosion warranty.. anyone had any luck? I have read a few posts and many say it depends if its been a result of a stone chip and this has not, I can still feel the laquer over it. I have attached some pictures to see if you guys think it is worth the hassle of ringing them?
    If not, could you guys advise me round about how much a good body shop would charge to sort it out? Or is there anything simple I can do? (Mechanically I am skilled, just my lack of tools let me down, artistically I am poor so painting and sanding is not my thing) Thanks guys
    PS my vehicle:
    sept 2005 (55 plate) 2.0 TFSI sportback on standard original 17" sport alloys (not s-line)
    27,129
    Usually a blow into front doors, across bonnet & the bumper, but some smart repair guy would maybe take it on, as its on the arch it maybe just a localised repair needed, just phone a local smart repair company & ask.
    Aug 2012
    Milton Keynes
    86
    Ye will do, but do you not recommend trying the Audi 12yr corrosion thing first? (Can imagine endless hours on phone will Audi so wanted to know if anyone has succeeded with them with the age of the car). Will have to ring some people while at work tomorrow I guess for quotes. Thanks for the quick reply NHN as per usual
    27,129
    Good luck proving it, the time wasted on this could be used for other more useful things, others have had mixed results, check repair costs then decide as it maybe as low as £100 for localised repair, but hey nothing ventured nothing........................
    Feb 2013
    78
    I would give Audi a call i know i certainly will be as i have some how only just noticed lacquer runs on the bonnet of my missus car and paint flaking off with runs on my front bumper from when they replaced it.
    Aug 2012
    Milton Keynes
    86
    I might just do both, ring Audi and see what they say (be helpful or other members with newer or older 8p's) and get some quotes too. Thanks for the replies.
    PS finally uploaded pics of my car if anyone wants a look
    http://www.audi-sport.net/vb/a3-s3-s...ml#post1834270
    Post number: 3444
    Mar 2013
    Hull, United Kingdom
    58
    Definitely go to Audi and get them to sort it out under the 12 year corrosion warranty. Had the exact same thing with my VW Golf and they sorted that under the warranty so should be pretty much the same jobby
    amit87 likes this.
    Aug 2012
    Milton Keynes
    86
    just an update, just went to Audi (to try my luck) and they got the paint depth gauge of their's. Automatically think they thought I was a chancer as my car is a 55plate (I am a chancer haha).
    Anyways got the paint depth gauge out, should read between 115-140 (microns I assume) but mine was reading anywhere between 140-200. He showed me evidence that car has been sprayed looking behind hinges etc (i dont have a keen eye so took his word and Id id get the car with not even 1 scratch so must be true).
    So its a no go, I didnt pass the initial paint thickness test. will have to ring and get some quotes.
    The guy did say it might be best to buy a wing and have it painted and then fit it, be cheaper than the work involved to remove current corrosion. But I will take NHN's advice and ring someone into smart repairs and gt a quote and post back.
    27,129
    I'll be honest, I knew they would say that.
    amit87 likes this.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    This sort of thing can be associated with the wheel arch liner retaining dirt in the wing area, where water sits, so rotting through the wing. Common on early MK5 Golfs. Ideally remove wing for proper inspection and prep for re-spray on the inside and outer surfaces
    amit87 likes this.
  1. New S3 with pics and front arch wheel gap
    By mojo555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2012, 10:07
  2. Urgent Help Needed - Lateral Acc Sensor with pic
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2011, 18:50
  3. Fitted my gauges , with pics ! :-)
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2006, 14:16
  4. Lots of Lovely New Hoses (with pics)
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2006, 12:53
  5. New member with pics of new A4
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2006, 19:47
