Volks AutosAH Fabrications
Results 1 to 9 of 9
    Jan 2013
    wakefield
    25
    S3 8P Roll on Road anybody no how to roll the 57 plate?????
    been for a blast out today to rotherham to stick the S3 on the rollers but when we got there they didnt no how to get it on the rollers.
    GR performance said we need to disconnect the rear wheels, now you can take a fuse out to do this on some of the models, but on mine you take the ESP fuse out and the car
    just tell you to do 1 and wont start.
    But then Ive also heard that if you disconnect the rear wheels and stick it on the rollers then the ECU does not allow all the power to go to the front wheels????
    Anybody any ideas lads how to do this correctly and to get a TRUE reading.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Go to a 4 wheel rolling road.
    Flat Out
    Apr 2007
    Essex
    144
    As above 4 wheel drive rolling road. Wouldn't even consider putting a 4wd on a 2wd roller, it will end in tears definately.
    Jan 2013
    wakefield
    25
    GR performance is a 4wd Rolling Road but apparently they said it would only work if we disconnected the rear wheels from the diff???
    they wouldn't even put mine on the 4WD because they said it would come up with negative figures on BHP because the 4WD system is variable meaning its front wheel drive till there is loss of traction on the front then it kicks the rear wheels in?????
    got me confused anyway there's got to be someone who no Exactly how to roll these
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Quote Originally Posted by NIC1985 View Post
    I don't know what your tuner has experience of,but they most certainly WILL run on a 4WD rolling road,as we've had mine on one loads of times.
    The Haldex may give wierd results occasionally,but only really with very high powered cars like mine,as it worked perfectly at anything up to 400bhp.
    Feb 2011
    Plymouth
    1,147
    Don't know if you can do it on the 8p but I know on the 8L they disconnect the haldex fuse
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Quote Originally Posted by smurfworth View Post
    You can on mine so the OP should have that facility but the point is it shouldn't be necessary.
    Jonse's Avatar
    Oct 2012
    376
    I was looking at getting my car RR to see how its going before getting some more mods.
    Why would you choose to go fwd drive over having it down AWD?
    What is the benefits or downside for just having it done FWD?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,393
    Quote Originally Posted by Jonse View Post
    There's no good reason.
    We tried mine in FWD a couple of times as the Haldex was playing havoc with the RR around the 500bhp mark.
  1. Replies: 3
    Last Post: 14th February 2012, 19:27
  2. Various ABS / Brake / ECU Error's Does anybody know how to sort ?
    By sc00byd00byd00 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd October 2010, 14:18
  3. Anybody know how to remove the airvents on the A3?
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2008, 20:10
  4. How well does the 1.8 engine cope with big mileage
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2003, 22:26
  5. How much does the heat affect BHP??
    By Drystone in forum Other Brands & Models
    Last Post: 25th April 2003, 19:41
