EM TuningVolks Autos
Results 1 to 18 of 18
    Jul 2012
    Aberdeen, Scotland
    47
    A4 Alloys fit an A3 ....??
    Hi folks,
    Im wanting to ask if A4 alloys of fitment pcd 5x112 18 x 8J ET 43 would fit ( not perfectly) my A3 BE 18x7.5 ET54 PCD 5x112..?
    replys much appreciated
    Euan
    2011 (61) A3 Black Edition 170 tdi Quattro, Brilliant red, Sat-Nav , reverse sensors etc
    2007 Honda CRF250
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    Im sure standard S3 alloys are 18x8.0", 5x112, ET54 so yes they should fit.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Jul 2012
    Aberdeen, Scotland
    47
    standard s3 wheels are the same, 18x7.5 ET54 PCD 5x112
    2007 Honda CRF250
    alfiejts's Avatar
    Jul 2006
    Lytham St Annes
    352
    Two things.....
    Firstly, the there's also the "bore", to take into account. You that's the size of the hole in the middle of the wheel.
    It's important as the wheel needs to sit tight on the hub.
    The a3 bore is 57.1mm but I'm not sure of the a4. If it's bigger then you can get adapters but it's important that the wheel sits tight on the hub as it's this connection that takes the strain of suspension movement not the wheel bolts....
    Also, if the ET offset is 11mm less, the wheel will sit further out in the wheel arch. It might be ok but you might find the tyres rub....
    2012 White A5 Coupe TFSi Black Edition
    (Was 2004 A3 2.0 TDi S-Line DSG, owned from 2005 to 2012....)
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Yes, they'll fit.
    As said, they are slightly wider and a lower offset, but they'll just fill the arches better than your standard wheels.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Persian's Avatar
    CEO
    Sep 2012
    186
    I have fitted OEM A4 S line (18x8 ET43) on my 8P1 without a problem, recently have had 225/40/18 tyres on it and no problem at all, just saving up to lower the car in near future. But yes they are same fitment as mine so shouldnt be a problem at all.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,403
    As said before it will actually fit the a3 and look better! The lower offset will make the wheels sit closer to the arch and more 'flush' but as advised check the centre bore as you may need spigot rings
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    Euan my dad ran this size on his s3 and when the car was lowered it rubbed on all 4 corners. They will be fine if you don't lower it or if you do you have to remove the inner arch retaining screws.
    2009 Suzuki GSXR1000K9 SE in White
    2012 Triumph Speed Triple R in Black
    2012 RS3 in Racing Mica Blue
    2012 A1 TFSI in Misano red (shared with mum)
    Jul 2012
    Aberdeen, Scotland
    47
    Has anyone pics of a4 alloys on their 8p a3...?
    the wheels im looking at are the genuine audi bbs ch alloys.
    2007 Honda CRF250
    c_w
    1,061
    They fit but they will look almost like aftermarket wheels (because all the reps sold for A3s/Golfs etc are the same as A4 fitments). It's true the arches get filled a bit better (this is particular for the rear) but the front will probably see some "poke" as the front track isn't too bad as standard.
    Persian's Avatar
    CEO
    Sep 2012
    186
    Sorry for the weird angle this is the only one I have and wheels are off at the moment so can't take any new ones.
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    Euan here is my dads car with the same wheels on it the front had a little poke and looked stupid to me. Better just get some CHs in the correct offset for the A3
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    They look small in 18s
    Feb 2012
    Northumberland
    88
    Quote Originally Posted by Rubz View Post
    they are not bbs, they are from an A4 DTM car
    Jul 2012
    Aberdeen, Scotland
    47
    Quote Originally Posted by azialex View Post
    that looks tidy with those wheels. Are they of the same fitting im looking at?
    2007 Honda CRF250
    Jul 2012
    Aberdeen, Scotland
    47
    Quote Originally Posted by A3simon View Post
    did need spigot rings for these wheels. I think they look a fine size to me
    2007 Honda CRF250
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    Not that I can remember
    336
    Looking at the set on eBay? I asked the seller about the size of the centre bore and he told me 80mm! Obviously had no idea what he was measuring as I'm pretty sure all a4s were 57.1 (b6/b7) and 66.6 (b8)
    Shame the OEM BBSs don't have the Motorsport stamped on the outside, makes them look like cheap reps
  1. audi tt rs4 18 alloys fit s3???
    By CHRISS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2006, 22:20
  2. Will these alloys fit?
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd September 2006, 09:18
  3. A4 with the 14 spoke alloys fitted
    By Soupie69uk in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th June 2006, 00:59
  4. Will my B5 17" alloys fit a B6 chassis?
    By technics100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th May 2005, 12:35
  5. Will these alloys fit my A6?
    By RyanA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th January 2005, 22:11
