Badger5Volks Autos
Results 1 to 11 of 11
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    HPFP cam follower
    Ok I've read all the guides I can find over the past week and thought I'd try to change my cam follower myself as everybody I've asked knew nothing of it. It arrived today and I thought I'd give it ago, it was 6pm when I started so was losing light fast. Took my 20 minutes just to get engine cover off ha, anyway got it off and got the two clips off. Went to release the fuel pressure but there was no bleed valve and on the guides there was 2 pipes - 1 rubber and 1 metal. Both mine are metal, started to look complicated and was getting dark so put it back together and will try tomorrow. Is there anybody in or around the Bolton area that wants to do it and show me? I'll provide beer tokens, thanks
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    The fuel pipe may be attached by a standard flared nut or Banjo bolt. If's it the latter then you need the right size spline drive. Even then it's a bummer to do, cause access not easy. Apart from this, the job is easy peasy!!!
    Be very careful not to break the connector on top of the HPFP....
    Jun 2011
    138
    Looks like you got the older type. You can either unscrew the banjo bolt on the pump and 17mm spanner on the other pipe or you can remove the pipe from the pressure relief valve. Id get it down to someone who knows or you can start rounding bolts and have fuel leaking.
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Jan 2013
    Bolton, UK
    402
    That's the thing, nobody knows. When I ask them they don't have a clue, even when I rang Audis parts department to order it they said it sits in the fuel tank so I'd have to take it to them as its a specialist job. The guides look easy, mines different from the ones on there. No where is open either now till Tuesday, I'm hoping a kind forum member nearby will do it haha
    Jun 2011
    138
    Would take about 30-60mins max to change
    Previous
    _G_
    _G_'s Avatar
    Jul 2011
    869
    HPFP cam follower
    Can you post a photo of it? Can try advise better that way.
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by _G_ View Post
    Will do later. Nobody want to do it for me around the Bolton/Manchester area???
    jimojameso's Avatar
    Sep 2012
    Surrey
    214
    Awesome gti are just down the road from you. Why dont you get them to do it?
    2010 TT RS - Sepang Blue - MRC 420BHP, 600NM
    2010 Stage 2+ S-Tronic S3 BE SB in Ibis White!! ....... SOLD
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by jimojameso View Post
    Would they do that do you think? Might call down there today, thanks
    Jan 2013
    Bolton, UK
    402
    Awesome isn't open today, think they're open tomorrow though. Will they do it on the day though or will I have to book in advance? Anybody had it done there? Thanks
    Jan 2013
    Bolton, UK
    402
    Awesome can't do it till the 9th of April, I'm working away from Tuesday so won't be home for a while. Don't think I'm going to find anybody to do it this weekend. They quoted £66 for an hours labour to do it as I already have the follower
  1. Changing HPFP / cam follower on S3 8P
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6 Days Ago, 08:06
  2. TFSI Fuel pump cam follower
    By KRL in forum Parts Requests
    Last Post: 2nd February 2010, 14:43
  3. Removing cam followers ?
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 18:37
  4. Cam follower inspection per Audidriver recommendation-2.0T
    By master mariner in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2009, 10:49
  5. 2.0 TFSI HPFP Cam Lobe and Cam Follower
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2008, 05:46
