Chris NottMonster Motorsport
Results 1 to 9 of 9
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    227
    PDC retrofit HELP!
    Hi all.
    I am retrofitting the PDC to my sportback 2009 modell.
    Bought all parts by NHN so think all the right parts are pressent. (tried reaching him with no luck)
    I am hoping you can help me.
    The PDC module i am useing is 8p0 919 475 M (see attached pictur)
    The connections i have found out so far is this.
    On the brown 16 pin plug
    -pin1 = +12v ( not shure if it is constant or ignition?)
    -pin8 = ground
    -pin15 = CAN low (orange/brown?)
    -pin6 = CAN high (orange/green?)
    -pin2 = buzzer
    -pin10 = buzzer
    Can somone confirm this?
    I am tapping innto the CAN wires from the trailer module. And +12v is also pressent by the module.
    is there any polarety +/- on the buzzer?
    I know it is easter hollyday, but this is my only chance to make it happen.
    The bumper is newly painted an installed.
    PS. I have searched the forum/nett henc my conection list, but this gave me lots of faulty errors and a black cluster until i disconnected the 16pin pugg from the PDC module.
    Thanks.
    Best regards
    J$B
    Norway
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    PDC retrofit HELP!
    Can't help I'm afraid but was wondering what PDC was?
    S3 Sportback
    27,126
    Jo, the 09 facelift pdc uses a different bus to the 08 & before larger sensors, so best option is run to front.
    Emailed schematic pics
    Jul 2009
    Norway
    227
    Quote Originally Posted by Wicked666 View Post
    PDC = Park Distance Control
    Best regards
    J$B
    Norway
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    PDC - Parking Distance Control
    or parking sensors
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jul 2009
    Norway
    227
    Thanks Nigel, I was missing the diagram showng the supply connections.
    So if i understad correctly, I can not tapp into the trailer CAN h/l signal? I need to feed it from the dash some place. right?
    What about my +12v. Do you recomend it also connected to the fuse box? Do you have the repair wire part no. Did not receive this!
    Replyed your email!
    Best regards
    J$B
    Norway
    Jul 2009
    Norway
    227
    What do you mean by "BUS i different" ?
    Best regards
    J$B
    Norway
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    PDC retrofit HELP!
    S3 Sportback
    27,126
    Jo, keep replies within email for now as we're going back/forth & its all over the place.
  1. 2.0 TDI Cruise & MFSW Retrofit Help!
    By zak123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4 Weeks Ago, 21:15
  2. A3 8P Sportback Kufatec Front Foglight Retrofit Help!!!
    By 1bigmac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2011, 14:47
  3. S Line Lower Bumper Retrofit Help
    By audigrr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2009, 03:44
  4. Rear PDC Retrofit
    By auroan in forum Parts Requests
    Last Post: 27th January 2009, 12:46
  5. S3 PDC Retrofit
    By mwstewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2007, 20:36
