AH FabricationsVolks Autos
Results 1 to 11 of 11
    Feb 2013
    54
    Dash lights have a mind of their own!
    When headlights are off, or DLR running, my dashboard lights have a mind of their own. Sometimes they're of, sometimes bright, sometimes dim...! Any ideas if this is a setting dependent on how fast I'm driving?
    I want them on constantly..
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Have you installed any after-market parts, OEM parts or completed any modifications to your car?
    Is this ONLY happening when your head lights are off and/or DRL's on or does it do the same with the headlights on/side lights on?
    Feb 2013
    54
    Quote Originally Posted by JRock247 View Post
    Only when lights off or DLR. I haven't tried it with sidelights, but dash lights up as normal when main lights are on. No modification whatsoever, car is 100% standard.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by controlz View Post
    Helps to state year of car but with VCDS you can set the cluster lights to be on all the time. I have done this on my 2006 MY but don't know whether it is possible on later models.
    The lighting is dependant on the ambient light in the cockpit and a sensor in the cluster increases the brightness when it's bright outside and reduces it when darker i.e. going into a tunnel.
    If you have auto-lights then I presume if they have switched on the lights then it is dark outside and the cluster will be stable. When auto lights are not switched on then the cluster assumes it's daytime and adjusts it's lighting accordingly.
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    I thought the light sensor only turned the lights 'on' or 'off' depending on the brightness outside, didn't realise it actually dimmed/brightened the interior lights as well, must have upgraded the light pack since I had it on my car.
    Fossie
    Rhubarb Triangle
    3,961
    There are two sensors if you have auto lights - one for the external lighting ( I think in the rear view mirror ) and one in the cluster.
    What basically I am suggesting is that if the external lighting sensor detects it's dark outside and has switched the lights on then it over-rides the internal one. If auto lights are off then the internal sensor in the cluster takes over !
    26,734
    As Mike says, there is an actual light sensor within the cluster itself which adjusts accordingly, there is a setting to change this within instruments.
    Feb 2013
    54
    I don't have auto lights.
    26,734
    Its nothing to do with auto lights, sensor is independent of auto lights.
    Feb 2013
    54
    Thanks Nigel. Easy to adjust?
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    The instrument lights can be coded to stay on all the time regardless of the light switch position, you can still control the brightness with the adjuster on the switch. It's a simple coding in VCDS
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
  1. Indicators with a mind of their own!
    By Abb in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th April 2013, 17:48
  2. interior light and sunroof have minds of their own?
    By s3welshy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2012, 09:18
  3. Indicators With a Mind of Their Own!
    By Wai-Fan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2010, 16:34
  4. Hazard lights with a mind of their own and ESP issues
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 13:29
  5. ESP light, mind of its own
    By pembo1976 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th November 2007, 21:43
