Volks AutosBadger5
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    GOT THIS FAULT !!
    00573 - Steering Torque Sensor (G269)
    008 - Implausible Signal
    All ive had done was drivers side cv boot replaced (driveshaft had to come off) as cv would not budge,and had cambelt done.cleared above fault but keeps coming back...........steering assist (44) in vcds.......terminal 15 is on and relay is on.........turned steering left/right multiple times (as stated in ross-tech) all the torque values do change. anything else?
    Full leather/19"wheels/cruise/
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by vw754 View Post
    See if this helps :- 00573 - Ross-Tech Wiki
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    like time since i chatted to you mike.....you helped me last year,anyway,nice to hear from you......il check the fuses under bonnet and side of dash in morning.......all that was done was take track rod end off the hub side in order to take shaft off,dont understand whats happened her.
  1. Anyone got this down pipe and manifold? S3
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2009, 18:56
  2. i just got this fault code..
    By ALPINE in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 15:40
  3. trace this fault code ?
    By 347 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th March 2008, 02:13
  4. Whats this fault symbol?
    By James333 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2008, 18:23
  5. Sold my S3 and got this!
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2006, 12:37
