Chris NottEM Tuning
    Aug 2009
    833
    Cam stretch symptoms
    Car feels fine but in the interest of science I did a vcds scan , found the intake cam at -5 and the exhaust at -7DegreesKW
    I read the limits are -8 to 8 but will this get worse quickly or slowly , ie should I be worried ?
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    What engine are you running? And how Did you determine the exhaust KW?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Aug 2009
    833
    3.2 and block 209 on vcds
  1. 3.2 cam chain stretch.
    By paddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2010, 22:09
  2. Stretched Cam chain / faulty intake camshaft adjuster solenoid
    By itssam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2009, 11:40
  3. S3 cams
    By peteA3tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2004, 09:08
  4. Cam Belt Tensioner - Known Issue??
    By Anito in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th March 2004, 07:55
