Belt Noise From Engine?
leeds2592
When I grow up, I want a 964!
Leeds
Hi all,
My A3 (info in sig) has started to make a noise from within the engine bay. It's quite hard to describe but it's a squeeking sort of noise that sounds like a belt and kinda like a turbo, although mine isn't a TFSI. The pitch of the noise increases as the revs get higher.
It's currently on 72,000 miles and is 6 years old so I know the cam belt and water pump need to be changed (getting done after next pay day). Could it be this that's making the noise? I don't want it snapping as I know I'll be pretty much ******** if it does.
I know it's pretty difficult to diagnose without hearing it in person, but any help would be appreciated.
Put a 17mm spanner end on the aux belt tensioner raised arm piece & move it so the belt seems a bit tighter, see if the noise goes, then if it makes a difference remove the belt altogether & see when running without if noise goes, if so then its either a belt, tensioner or pulley.
