Chris NottJMB Retrofits
    warrenlord's Avatar
    Apr 2010
    778
    Loom wire! Airbag seat wire! Please help!
    Please could someone confirm what type of wire is used for the plugs under the seats in the a3. What gauge wire and if its a specific type for the electrics and air bag plug ?
    Any help is very appreciated !
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,392
    is there an exact wire you need? like one from the airbag plug or one for lumber support? the repair wires are different depending on what it is you need to connect.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    27,089
    You need to consult a wiring schematic for your seats, the gauge varies depending on application, using incorrect gauge can cause fires, so don't skimp at all, use the proper rated wired for the system you need to connect.
    When working on airbag systems, adding solder has been known to cause resistance in circuit & then cause airbag light/issues, so be warned, audi tech's use new looms or crimp, not solder on these systems.
    warrenlord's Avatar
    Apr 2010
    778
    right cool noted NHN, basically NHN knows as ive asked him before... its the wires for the airbag plug to be specific, i used different plugs to enable fitting the seats i have.
    its been re wired with solder which has been said seems to be throwing up the airbag light. just an annoying little job that needs sorting.
    NHN do you mean a diagram of the specs on the seats ? Thank you very much
    27,089
    Wiring diagram of the year of car, chassis & yes seats.
    If its the airbag system not seeing correct resistance, try removing solder piece & twist wires together temp & add tape & see if the issue returns, that way its not got any solder to add resistance & would let you know where issue lies.
    warrenlord's Avatar
    Apr 2010
    778
    thanks ! see how i get on with it.
  1. DRL BI XENON 2010 Wiring ( 2010 CEMC MODULe) PLEASE HELP
    By Chris Coates in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2013, 14:36
  2. Loose wire in loom (with injector wiring) please help!!!
    By philreed52 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2011, 19:45
  3. Seat Wiring loom
    By Shao_khan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2007, 15:06
  4. S3 stereo wiring been modified - please help
    By darko in forum In-Car Entertainment
    Last Post: 21st July 2006, 15:52
  5. Drivers seat wiring loom
    By Bongo163 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2006, 17:12
Tags for this Thread
