Results 1 to 9 of 9
    JPK
    May 2012
    278
    Loud squeaking from front end?
    The noise has only started in the last couple of days. It is loud and does my head in. Mainly makes noise in the morning when its colder and going over bumps or undulations in the road. Noise reduces significantly and is intermittent later in the day when its warmer and the car is at temperature. Had some suspension work done last week but was perfectly fine for the first few days/200km.
    Had the following installed in the front end 4 months ago.
    Whiteline anti lift kit, h&r sport cup kit, whiteline front control arm bushings, new oem strut mounts bearings, 034 Motorsport street density mounts
    Had the following installed last week:
    New h&r front dampers (old cup kit dampers were incorrect), whiteline adjustable end links, whiteline bump steer correction kit, tyrolsport deadest collar kit, oem ball joints, oem inner tie rods. New brakes were also installed. Everything was torqued to spec and greased where appropriate.
    I am thinking either OE sway bar bushes (pain in the arse to check/replace) or possibly OE strut mounts (even though they are only 2500km old). Neither of these should really be failing though..
    Anyone got any ideas?
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    27,097
    Spray some wd40 into the arb bushes, see if it goes.
    JPK
    May 2012
    278
    I suspect the bump steer correction kit. Drove it in the rain today and the noise was terrible. Far worse than in the dry. Especially loud over bumpy surfaces and when turning at low speeds. Also when stationary and turning the wheel. Won't have a chance to get it up on a hoist and checked out till mid week :/
    Will try some wd40 tomorrow on the arb bushes, however if it is the problem that will just be a very temporary fix right?
    JPK
    May 2012
    278
    Can the front sway bar bushings be replaced without dropping the subframe?
    27,097
    Yes wd40 was just to ascertain where problem was, then decide on what to do.
    Depends on if you'd split the existing bracket, if you did then its maybe possible to get it all of without removing arb, but you may have to loosen the sub to drop it a little bit, you don't actually have to remove the sub anyway when doing the arb, just drop it down & hang on the bolts.
    JPK
    May 2012
    278
    Thankyou. What would you estimate in time to replace the front sway bar? Considering doing it anyway, was just put off by the potential high labour cost as I wouldn't tackle it on my own.
    27,097
    Depends on the person doing lol, but half a day realistically if not done before.
    I have a front fat HR arb for sale for a fwd 8P/MK5.
    JPK
    May 2012
    278
    Probably cost a fortune to ship to me!
    Yes it was the ARB bushes. A bit of wd40 quietened it right down. Funny that it happened right after installing those parts. Must be related to the tougher end links not giving as much?
    27,097
    Why where are you located?
    New arb bushes can do this if not lubricated before fitting, I recall some Eibachs I fitted sometime back had a tube of lube supplied with.
  1. Replies: 4
    Last Post: 22nd September 2010, 23:15
  2. Whine noise from front end - speed related
    By 1210tech in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2010, 20:45
  3. knocking from front end
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th July 2007, 23:54
  4. Squeaking From front
    By Glenn A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2007, 20:40
  5. Whining from front end
    By amazon in forum A8/S8 forum
    Last Post: 17th June 2004, 23:49
