Sky InsuranceChris Nott
Results 1 to 26 of 26
    Apr 2012
    59
    A3 2.0 TDI 170 is the turbo gone ?? ** pics inside **
    Right guys, my car has been smoking on idle and its a white/blue smoke (burning oil somewhere) that is rather strong smelling of unburnt fuel.
    Just took off the pipe to the inlet manifold to see all this crap, is this signs of the turbo has gone ? Seems like oily residue and carbon build up as pictured.
    Any help would be great.
    Feb 2011
    Plymouth
    1,110
    Unburnt diesel fuel will be black coming out the back, those pics just show the soot build up which is normal with diesels.
    Jan 2012
    SW London
    794
    yup mines the same. u having any issues?
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    742
    Unburnt diesel burns white smoke in the exhaust, oil burns blue, & over fuelling burns black smoke. Looking at the pictures your EGR pipe looks perfectly normal.
    When did you last change your fuel & air filter?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Apr 2012
    59
    checked the air filter and it looked clean, was on long life services but had N8 change it to normal services.
    Gonna go get replacement filters tomorrow and see if it helps.
    Can't see how the filters are causing white/blue smoke tho !!
    max69vk's Avatar
    Apr 2012
    742
    Everything this works in relation to one another, if you don't care of the basics it will eventually always affect the more complex areas of the engine. Are you sure the white smoke isn't water vapour?
    Apr 2012
    59
    Yes mate its more oil burning smoke than vapour.
    Plus the smell is well strong.
    Went to change the filters today but been given the wrong one so gonna have to go back and swap it tomorrow.
    Apr 2012
    59
    Well guys just changed the fuel filter and it was black.
    The worrying thing I'd so is the fuel, I tool some out of the chamber into a lid and it was very black like its contaminated with oil.
    How can oil get into the fuel ?
    max69vk's Avatar
    Apr 2012
    742
    The lift pump will be under the rear seat. Remove this to get access to the tank. FYI fuel in the filter shouldn't be black, if it is this is usually due to a failed tandem pump or leaking injector seals.
    Apr 2012
    59
    Why would I need access to the lift pump in the tank Max ?
    max69vk's Avatar
    Apr 2012
    742
    Quote Originally Posted by xtremedetailz View Post
    Sorry, was reading your last post on the phone & thought you said you wanted to get into the fuel! :D
    Apr 2012
    59
    May 2009
    south yorkshire
    628
    i know darkside development do the injector seals for these , cheaper than tps do them. it is mostly like the injector seals that are leaking , pointless swapping the fuel filter till you get them sorted as the new filter will be ruined almost instantly .
    max69vk's Avatar
    Apr 2012
    742
    Quote Originally Posted by hollow View Post
    True, but if the filter is black again within a few 100 miles he'll know for sure its a problem on the injection side. If its still clean & there's still blue smoke its time to investigate the exhaust side of the sytem.
    Apr 2012
    59
    It had new injectors less than 10k ago from Audi under the recall and I'd think they would have put new seals in.
    infernalzen's Avatar
    Feb 2012
    29
    BG244 BG 244 Pro Diesel Fuel System, Injector Cleaner & Funnel | eBay
    i use this to clean my injectors.
    it supposidly makes the inside of the engine look brand new.
    im hoping the turbo gas path gets cleaned as well.
    id be interested to see it this would work of your car.
    Feb 2013
    Cornwall
    81
    I had the same problem with the black fuel filter! Took it to audi and it turned out to be the tandem fuel pump on the right hand side of the engine. Basically the rubber seal breaks down allowing fuel and oil to mix! Hense the oil on the fuel filter.
    They also said that also contributes to the injectors going down!
    My turbo has also started whistle but with no loss of power or anything, which I think has something to do with the fuel oil mix and fuel thinning the oil so therefore less lubrication for the turbo.
    Audi replace the pump, fuel filter cleaned fuel lines and tank and I also had the injector recall at the same time.
    Going to do a few cycles of new oil to see if that helps the turbo whistle??? I doubt it but its worth a try and a lot cheaper than a new turbo!
    Hope this helps
    max69vk's Avatar
    Apr 2012
    742
    Even if new seals are fitted (which new injectors come with) it doesn't mean they've been fitted correctly.
    Apr 2012
    59
    Cheers guys, very helpful as usual.
    Gonna try the tandem pump next week and hope that cures it.
    If not its off to Audi for them to check the injectors they fitted.
    That cleaner looks like decent stuff, would it not be too abrasive and damage anything?
    Apr 2012
    59
    Can anyone tell me how to change the tandem pump ?
    Apr 2012
    59
    Anyone
    Jun 2013
    22
    Brought a 2007 170 TDI Quattro on Friday and noticed this issue as soon as I got it home
    Lots of exhaust fumes on startup, regardless of the weather outside. No fumes at all when driving, only when idle.
    Turbo is also very whiney.
    Its my first TDI so I can't say for sure if theres any affect on power, it's driving fine but Im not pushing properly until I can find out more info on this.
    Looks like Im going to have to ring up Audi then
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    Quote Originally Posted by MyMateDaveDJ View Post
    If its making the 'siren' noise or whining then your going to need a new turbo.....perfect opportunity to upgrade to a better one....
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    May 2012
    RETFORD, NOTTS
    1,748
    if the tandem pump is the same as on a 1.9pd i have one spare for sale :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Feb 2011
    Plymouth
    1,110
    The turbos wine anyway, it's only when it becomes so loud that people in the street turn around thinking its a police car that you need a new one.
    Oct 2012
    Aldershot, Hampshire
    190
    Quote Originally Posted by mjr901 View Post
    My turbo has made the siren noise for the last 30k miles. It can be caused by a slight difference in tolerance. Or bearing failure. Any decent mechanic can do a health check for about £150 which will give you a yeh or nah on replacing it. My car is now on 100k miles and I'm changing the tandem pump on Friday.
    And try a filter change ad glow plugs. I had really bad black smoke change the glow plugs and it disappeared.
  1. TDI 170 - need new turbo ASAP!
    By eddscott in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th November 2012, 09:28
  2. TDI 110 lost the turbo for a few minutes????????
    By benny-g in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2009, 23:11
  3. 2.0 TDI 170 max torque through the clutch?
    By Lukeyb in forum Tuning
    Last Post: 28th December 2008, 01:23
  4. Cleaned the car, New pics inside!
    By Booth_S4 in forum Photography & The Digital Darkroom
    Last Post: 22nd January 2007, 18:42
  5. The Results are in! - TDI 170 MPG Figures.
    By PJLarge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2006, 20:37
