Chris NottBadger5
    vag_fan's Avatar
    Mar 2013
    13
    Replacement ABS Unit
    Hi
    My 2006 a3 is currently getting the ABS unit replaced under warranty as it suffered from the well known ESP light being permanently on.
    The garage originally purchased a reconditioned unit, but says that it wasn't happy with it as it only worked intermittently. Therefore they are reluctantly purchasing a brand new unit from Audi which they say is costing a fortune.
    My question is this, will the new unit be modified from Audi to ensure i never get this fault again? I don't want to be running the car 2 years down the line when its out of extended warranty for the sensor to fail again.
    Cheers.
    vag_fan's Avatar
    Mar 2013
    13
    bump
  1. replacing CD unit
    By mdwyer in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2005, 21:53
  2. Cheap Replacment MAF units.
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2005, 15:59
  3. New BOV/Div to replace bosch units
    By powerls in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2004, 23:05
  4. 2004 A3 Replace Head Unit
    By Cyanide in forum In-Car Entertainment
    Last Post: 9th April 2004, 01:48
  5. Replacing head unit on TTR
    By AlexStanley in forum In-Car Entertainment
    Last Post: 14th March 2004, 18:56
