Badger5Volks Autos
    Mar 2013
    22
    Red face Hi..new and need some wheel help.
    Hi guys,
    I am new and already calling on you for help.
    I was a member on RS246 as i have has a couple of RS4's but just made theswitch to a S3 and loving it !
    I am unfortunately not too clued up on wheels and looking to change my Black editionsfor the same but in 19's.
    Will the following fit :
    19X8.5,ET 45,PCD 5X112, C.B 66.6
    I was planning on running spacers but i know certain ET'swill fill the arch more. Also what tyre width is best to avoid any rubbing taking into account i will add 25mm H&R's.
    Thanks in advance for any help and explanation tomy ignorance.
    TDI140's Avatar
    May 2011
    1,347
    They will fit on your a3, you need to remove the rear arch screws and run 215/35/19 tyres (stretched) and thats all, you should be ok and also be able to drop around 45mm aswel
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    br20vt's Avatar
    Sep 2010
    Middlesbrough
    141
    They'll work fine with anything up to a 235 tyre, and as above remove the rear arch screws to avoid the annoying scrubs over bumps.
    Ibis S3 8P3 - Airlift V2 / S63 AMG wheels / RS3 Grill / Recaros
    Previous: Polo 6n2 20vt / S3 8L GT28
    Instagram: @bradraistrick
    http://www.audi-sport.net/vb/a3-s3-s...s3-thread.html
  1. Hi I'm new and need some help
    By John2708 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2013, 22:25
  2. new to forum and need some help please
    By midnight-massacre in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2011, 23:00
  3. New BBS Wheels - Need Some Tyre Help!!!
    By SunnyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2011, 13:57
  4. I am merely female and need some A3 help!
    By ""pinkgirl** in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2010, 13:04
  5. Im new and need Help
    By WannabeRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2003, 19:41
