Sky InsuranceEM Tuning
Results 1 to 23 of 23
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Hey fellas,
    Just looking at getting some advice and maybe some reassurance from some of you guys who are running Stg 1 or above.
    My car is an S3 S-tronic, just over a year old, recently serviced and as far as I can tell, in good health. I decided to take the plunge and fit a Neuspeed P-flo CAI and was pleased with the results. Lots of sucking noises and a small amount of DV on lift off.....all good. I then ordered a Shark Stg 1 map and STS and installed the performance map. I went for a spin and noticed that (other than a big performance increase) when the revs are going through the 3-4k rpm range, I get a sort of flutter noise. It's like lots of small DV noises that happen really fast (psst psst psst psst). I must stress that this is while I am still accelerating, not on lift off.
    I've contacted Shark and they confirm they have issued the correct map for the S-tronic and have suggested it could be a characteristic of the P-flo. My worry is that there is a leak somewhere and I could be causing damage to the turbo if it is some sort of surge.
    Has anyone else on here found the same results after a remap with a P-flo fitted, or indeed any other CAI? I plan on taking the P-flo off and re-fitting the standard engine cover/air box to see if the noise is still there.
    It'd be great if someone could share a little advice on anything I could do to check for problems. I have checked for codes using the STS and found nothing.
    Cheers in advance fellas
    Smiffi
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,406
    Follow Brodster On Twitter Add Brodster on Facebook
    Personally your doing all the right things. Get the P-Flo off and get the original back on. I have heard afew people binning the P-Flo for various reasons. The Shark Stage 1 remap is IMO one of the best around and thats not beig biased as Im a dealer. I have tried numerous remaps from the top companies and for overall reliability and driveability it wins hands down. Out of all the S3's I have mapped not one has had any problems and afew of them have had other tuning mods done such as CAI's, twintakes so see how you get on with the original fitted and report back with the results.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Oct 2012
    Fife
    59
    Could this not be a faulty Diverter valve causing this?
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Quote Originally Posted by Brodster View Post
    Cheers for your thoughts Brodster. I'll see if I can get it off tomorrow and report back.
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Quote Originally Posted by GuyJ View Post
    GuyJ, my car is a 2012 so has the Rev D diverter valve fitted which I believe are supposed to be really well made and reliable. I will look into replacing it if the noise I still there once the CAI is off.
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Just a quick update, when I took the factory air box off originally I noticed it was quite oily around the big pipe going to the turbo. I take it this is why people fit catch cans? Or could this point towards a problem?
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Nothing wrong with your car. It is slight compressor surge that you can feel, as the S3 turbo has a larger compressor in relationship to the exhaust housing. The only way round it is to cap the mid range boost or change turbo.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,050
    I have SHARK Stage 1 with Milltek TBE but stock air box and havent noticed any untoward sounds.
    Sounds like a CAI issue.
    Car is also DSG btw.
    Good luck
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    Hi Rick, thanks for you post. I take it you have you come across this noise before?
    Jan 2012
    Stockport, Cheshire
    748
    Yes, many times. The compressor flows a lot of air - upto 400hp worth and yet spools up very quickly. This is due to the small hot side which means that too much air flow is produced low down the RPM range where the engine cannot consume it. As a rule normally map to just below this surge line unless a customer wants all out.
    Rick
    Dec 2011
    North East Scotland
    17
    Same thing has happened to mine 2012 but manual been running stage 1 fine for a good few months got the amd cai kit fitted within a few hundred mile engine light came on with code p2177 running lean so flashed it back to original map running fine now !!!!!!
    Got a service due in the next fortnight so going to wait and see what audi say and take it from there .
    just means might have to forget about stage 1 and go for stage 3 instead hahaha
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    100% normal. It's what they do.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    38 seconds into this video is the noise your hearing I should think.
    Yes different car, but running gear is essentially the same.
    It is normal.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    I've done 20k with the P-Flo. Very happy with it, bar the heat-soak issues as its black...and metal....so design is a little poo in that respect.
    But its up to stage 2 no problem and 340bhp.
    Dec 2012
    244
    Post Remap Question
    I asked the exact question last week and got all the replies I was hoping for. It's normal!
    I'm running stage 1 and neuspeed intake.
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Quote Originally Posted by mjr901 View Post
    It is normal.
    That is pretty much the noise I get mate. It must be a p-flo thing as I've never heard it on any video with any other CAI.
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    Post Remap Question
    Rick
    Rick, if its a surge can't that harm the engine? I'd have thought it would have been mention a lot more as the Shark Stg1 is a generic map isn't it? Maybe it's just the P-flo that vocalises this surge? That's 3 people on this thread with it and all have P-flo fitted.
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    Quote Originally Posted by Smiffi View Post
    A friends Edition 30 Golf stage 2+ with ITG makes it. it's not just a P-Flo thing for sure.
    Smiffi's Avatar
    Feb 2012
    Tyne & Wear
    154
    That's a shame cos it sounds a bit strange. I take it your car does it too?
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,794
    yup, from the word go.
    Jan 2012
    Stockport, Cheshire
    748
    The amount of surge here is probably going to have minimal effect on turbo life, but I can't quantify it.
    Anything that frees up (read: makes louder) the intake system is going to amplify the sound.
    Rick
    Jonse's Avatar
    Oct 2012
    376
    Hi All i get this aswell. I dont have a remap but have the revo air intake and also a milltek cat back. I was hoping it would get fixed with a remap but doesnt sound like it
    Mar 2013
    155
    Remapping your car will not get rid of an induction noise..
    Does anybody have Rolling Road figure 'before' and 'after' with an induction kit please? Just for my own interest. Cheers :D
  1. S3 post remap N249 bypass . ! . ? . ! and fuel pressure reg question
    By VAG-Slag in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2011, 18:34
  2. post remap question
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2006, 19:59
  3. Tyre Life post Remap.. Oops..
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th May 2005, 08:41
  4. Interesting Post remap dyno...
    By robthehungrymonkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2005, 21:40
  5. Another remap question!
    By imported_dumpvalve in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st December 2004, 17:19
