Chris NottSky Insurance
Results 1 to 10 of 10
    Tdp
    Mar 2013
    Leicester
    21
    Smile Rns-e software issue- No version displayed!
    Hi all, newb here
    I recently fitted my a3 with the rns-e unit and I'm very impressed with it,
    however when I try to see what version of software I'm running all I see is: X__
    is this normal as the unit is running perfectly?
    any advice would be great
    thanks
    26,776
    Welcome to the forum.
    That rns has been hacked probably to change the pin code for it, so potentially stolen.
    Tdp
    Mar 2013
    Leicester
    21
    Thanks for the reply,
    It was purchased off eBay from a seller that has various rns-e units for sale and the business seems reputable?
    Is there anyway around this hack as it sounds a little 'rogue' to me?
    cheers
    26,776
    Yeah you'd need older firmware dvd & latest, plus vcds to fix that.
    Tdp
    Mar 2013
    Leicester
    21
    Where can I get these Dvd's from? I have access to vcds luckily
    26,776
    Ebay is a good start for a genuine older version, then use your current to update it again.
    Tdp
    Mar 2013
    Leicester
    21
    That's great! Thanks very much for your advice
    where would vcds be required?
    26,776
    To put the rns in downgrade mode.
    Tdp
    Mar 2013
    Leicester
    21
    Oh ok, sounds rather confusing
    Mar 2011
    Cleveland
    878
    If that's the case, won't the PIN be void if you change the firmware?
  1. RNS-E / GSM and Nokia N series phones
    By consilio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2007, 11:49
  2. RNS-D retro fit, Need Help please
    By banannaboat in forum In-Car Entertainment
    Last Post: 2nd November 2007, 10:23
  3. Bluetooth - RNS-E - VAG-COM Programming help!
    By sijones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2007, 16:16
  4. S3 rns-e in A4?
    By jwhat in forum In-Car Entertainment
    Last Post: 28th October 2007, 15:11
  5. rns-e
    By quattrov6tdi in forum In-Car Entertainment
    Last Post: 23rd October 2007, 00:17
