    Jan 2013
    Front suspension or engine "feels loose"
    Hi,
    I have a 2007 S3, and when I test drove could feel some play in the engine or front suspension.
    Thought it was probably the front control arm bushes as my earlier MK5 Golf felt similar.
    Upgraded to Poly Urethane bushes, and although feels tighter there is still play somewhere?
    It is noticeable when you go over a cobbled road or a sudden bump to the front end suspension.
    It is really faint and I am probably just being anal, but it bugs me!
    It just feels like play in the front end somewhere, only minimal but enough to notice
    Anyone had similar experience?
    Luke
    Jun 2011
    Great Melton Norfolk
    1,340
    How many miles has it done? Could be track rod ends.
    Jan 2013
    Quote Originally Posted by gen.heinz guderian View Post
    Hi,
    67k miles
    Luke
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,158
    What condition are the front shocks in?
    Jan 2013
    Quote Originally Posted by MrLapou View Post
    Dont know, thinking of possibly stripping off front strut to see if top mount or shock is damaged?
    Would make sense if the shock is a little lazy, or if top mount has play in it I guess?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,785
    If the engine is moving on it's mounts,there could be significant wear in the mounts,and it may be worth having them looked at......certainly if the car has been modified at all,these are worth uprating in any case.
    Otherwise,on any car of this age,parts like the suspension bushes will wear,and when i had mine replaced,the original ones did look a bit sorry.
  1. squeky front suspension
    By misledyouth in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 12:26
  2. S3 Front Suspension Knock
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 12:25
  3. Front Suspension Woes (a wee bit longish)
    By IanWood in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th May 2004, 14:04
  4. My engine feels loose!
    By alibob in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2004, 09:06
  5. A/S3 front suspensions??
    By Drill in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2003, 14:33
