Chris NottEM Tuning
Thread: Rear Washer Jet
    Oct 2011
    Rear Washer Jet
    Hi Guys,
    It appears my rear washer has stopped working, or at least water is no longer getting to the jets. I'm guessing it is blocked, is it possible to remove the cover and clean it?
    Any advice would be much appreciated before I go pulling things apart!
    Rom
    Rom's Avatar
    May 2010
    Bristol
    444
    Re: Rear Washer Jet
    You can try in blocking the holes with a pin.
    Or from behind with an airline if you have access.
    But have a search, as there is a common fault where pipe breaks I think, and leaks into boot, eventually breaking wiper motor.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    Jun 2011
    Great Melton Norfolk
    1,348
    Check the pipe hasnt split in the boot.
    Jul 2010
    561
    First thing to do is take the cover off and pop the water sprayer off the wiper assembly. Then try squirting water with it off. If it shoots out then the water sprayer is blocker and you can unblock it with a pin. If there's no jet of water then start looking for water leaks from under the inner boot liner/inside the boot when you spray.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Search!!! Common problem that's been covered over and over!
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
  1. Rear washer jet > stopped working > HELP!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2008, 19:34
  2. rear washer jet
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2007, 13:37
  3. Rear washer jet is weak
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2007, 19:43
  4. Rear washer jet
    By Hotscar in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2007, 08:23
  5. S3 rear washer jet problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2004, 15:34
