Chris NottAH Fabrications
Results 1 to 8 of 8
    Jan 2013
    159
    S3 fuel readings all over the show....
    Basically, is there anyway to test this with VCDS etc? Or does it need some kind of calibration?
    Range said 60 miles when I turned it off yesterday, turned it back on and its on 30miles left!! So getting rather dangerous
    Or can I clean/test the fuel sender myself?
    Pretty weird fault to be honest...need it sorting ASAP!
    2007 S3 by the way that has done 64k
    jimojameso's Avatar
    Sep 2012
    Surrey
    213
    It changes depending on current fuel consumption. Probably dropped as obviously when you start the car its cold and fuel consumption is much worse!!
    2010 TT RS - Sepang Blue - MRC 420BHP, 600NM
    2010 Stage 2+ S-Tronic S3 BE SB in Ibis White!! ....... SOLD
    Jan 2013
    159
    Yep I understand that....but explain how it reads as a full tank when I filled 20 litres from empty in it!
    Its like I am playing roulette
    27,043
    Well I would be swapping the prelift pump/sender, but as yours is a Quattro it has 2 in the system chain as such, as the tank is each side of the prop.
    There are measuring blocks to show the quantity detected, you'll have to look through yours to see what it shows.
    Jan 2013
    159
    Excellent thanks. I will look into this when I return home on thursday.
    Can you tell me which setting it is, have you ever cleaned or replaced some before and are you around the Northwest area at all?
    Jan 2013
    159
    I will look at this on Thursday or Friday... Any advice would be great
    Jan 2013
    159
    Right fuel sender 1 is showing 24litres (gauge is just above half a tank) and resistance is 181.
    Fuel sender 2 has no resistance and no fuel content...
    Time to remove rear seats?
    Jan 2013
    159
    Cleaned both connectors for fuel sender and no luck after putting back together
  1. Wandering all over the road...
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2011, 14:06
  2. idle all over the place
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2009, 11:23
  3. Rattles all over the place
    By mark88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2005, 12:53
  4. Buy fuel over the net.
    By Soupie69uk in forum General Chat
    Last Post: 23rd September 2005, 21:48
  5. Boohoo.S3 is leaking all over the place!
    By ianhg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2005, 21:02
